Hi, you can get peugeot clarion radio codes from the link! I have used them and they email the code to you cheaper and quicker than going to main dealer. CLARION PEUGEOT RADIO CODE United Kingdom Gumtree
Contact the dealership. Only they can reset the code.
SOURCE: peugeot 206 radio code
Your radio is made by CLARION and the only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C7000000 + + + + on a label somewhere on the metal casing.
(There are usually two barcodes on one label. The one required is the lower one )
T
If not then it will only be available from your Main Dealer or a Decoding Service
SOURCE: Torque setting for peugeot 206
hallo
If you have normal 1.6 liter 206:
max bolt lenght:176,5mm
20Nm and aditional 240°
1,6 liter 16valve engine
max bolt lenght:122,6mm
20Nm and aditional 260°
Marko
SOURCE: Rear clunk in Peugeot 206, 2002
you may have a problem with a sticking handbrake
usually what happens is one of the brake shoe linings comes off and gets stuck when the car is stopping
the noise your hearing in the brake releasing
SOURCE: ive got coolant water coming out as fast as i put in my 206 gti
Freeze plug, head gasket, hose to the heater core. You have to get back there and look.
Testimonial: "hi thanx for getting back to me , i found the problem it was the pipe that comes from the water pump then goes into the thermostat housing.thanx again"
