Look inside your fridge at the back wall, just above the level of the top of veg box. You may have to squat a bit to get your eye level down to it. There is a gutter that collects condensed water and at left end of gutter is a drain hole. In my Miele it kept getting blocked and so water spilled over and ended up on bottom of fridge like yours. For a quick fix it you need to clean that hole by poking a chopstick in it. For a permanent fix, turn the fridge around so you are looking at the back of it with all the condensing pipes. On the right you will see a clear plastic drain tube that runs down to a heat unit. This is the overflow from that drain hole I mentioned. You need to get one of those brushes on a flexible metal cable. I got mine from Amazon, Prettyui refridgerator scrub. You poke that up the tube from the bottom to clear out all the gunk. I then used a Turkey baster to flush that tube from the top with water to get the last bits of gunk out. Works like a dream - never had water in bottom of fridge again.
Plugged evaporator (cooling coil) drain pan opening or plugged drain line.
Check out these tips...they can help you figure out what is going wrong with your refrigerator
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
