Washing Machines Logo
R
Ralph Ding Posted on Feb 05, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Manual for NW 892 nec washing machine - Whirlpool Washing Machines
nomess
Level 2:
  • Expert 343 Answers
  • Posted on Feb 09, 2015
nomess
Expert
Level 2:
Answers
343
Questions
Helped
101342
Points
753
2helpful
Washing machine not spinning, stops & the letters LE flash, washing machine is a NEC NW-892 Millenium
It sounds like your lid switch is not working correctly, look to see if there is supposed to be a finger that protrudes from the bottom of the lid and enters a hole in the top of the washer, this is a safety switch to ensure the lid is closed, it is possible the actuator finger is broken or missing, If this is the case, I have heard of people manually actuating the switch to finish the load, I am not suggesting that because there is a safety issue, but it has been done. Your washer might not have an exposed actuator,it could be hidden under the washer top, but the LE error code indicates the lid is open.
Hi I have an NEC NW 892 and when I plug it in there is no indication of any power getting to the machine Any help would be appreciated. Thankyou Dr Bob
Sorry but with such a 'basic' fault it is virtually impossible for anybody on this forum to remotely guess what is wrong with your washer.
It could be internal wiring/plugs sockets, control panel switches and/or control PCB.
I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
Sorry again and good luck,
John C
I'm looking for a manual for NEC washing machine NW-452
it must have been provided with the machine
Nec washing machine model nw-893a. maintenace manual electrical manual
Hi I have a NW-893a and my control panel only lets me go on one setting and needing a new one were can i buy one please
1helpful
I also have an NEC NW-452 Washing Machine,it has stopped working completely,doesn't power-up at all,the User Manual troubleshooting guide is no help at all,I tested it it with a Digital Multimeter to see...
take the top off and follow the mains cable to where the cable is connected in the terminal block it could have come loose or the cable itself is at fault check the wire from the plug terminals to the terminal block eric
3helpful
NEC NW 892 Errror E9
This error is related to the pressure sensor
check connections or replce pressure sensor
Check at the water source end of the hose and make sure the filter is not occluded. Both hot and cold. more likely the cold side as the hot water may disolve the particles more easily.
If all else seems good you will have to replace the sensor
Nec nw-891 washing machine will not complete the programmed cycle
Apparent malfunction in the timer circuits. Specific Component replacement not available.
The NW - 891 NEC washing machine does not finish the third cycle or drain?
Our nec washing machine nw 891 leaks water into drum when finished , I think it needs new washers, is this hard to do?
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
