Vestax Vci 100 Midi Controller Logo
sashaqq Posted on Feb 05, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
WHAT TYPE OF TRANSISTOR Q1 ON THE BOARD NEXT TO THE SYSTEM CONNECTOR
TRANSISTOR BURNED AS COAL .THANKS FOR THE REPLY
rhodesworks
Level 3:
Top Expert:
  • Vestax Master 3,159 Answers
  • Posted on Feb 09, 2015
rhodesworks
Vestax Master
Level 3:
Top Expert:
Answers
3159
Questions
Helped
562592
Points
331463
Your best bet is to contact Vestax Support directly. Their USA phone number is 1(888)498-4788 Mon-Fri 10am-5pm PST
1helpful
Need schematics for Peavey max 112 bass amp. Power circuit board has copper traces burned off so a layout of the board traces will do... Thanks for any help
Try to find a new board. Trust me, you are not going to fix it - there is a reason the traces and board are showing burn marks. Either scrap it or just buy another one. If you toss it cut the power cord off next to the chassis.
2answers
Why does fuse blow when unit is powered up
I rather suspect IC1 TDA7293 is the cause of your problem. If this is the case you will need to check the speaker/s
Korg i3 keyboard no sound out
Step 1:
Check the setting of LOCAL CONTROL in GLOBAL mode.
Go to GLOBAL mode page 1 (Figure 1-2):korg-i3-keyboard-no-sound-out-fuxmm42irvf2p03kxwfdv02c-5-0.jpg
korg-i3-keyboard-no-sound-out-fuxmm42irvf2p03kxwfdv02c-5-1.jpg Move the cursor from the MASTER TUNE to LOCAL CONTROL. Setting LocalControl should be in the ON position.
When the setting is OFF,set it to ON (use dial TEMPO / VALUE or DOWN / UP button).
Go back to ARR or PROG mode,and play the key to check audio.
Step 2:
If in step 1, the sound still does not exist, then it is a hardware problems, and the possibilities are :
Figure 3, the section in red shading is a block may be damaged.korg-i3-keyboard-no-sound-out-fuxmm42irvf2p03kxwfdv02c-5-3.jpg
Figure 4 is a scheme. korg-i3-keyboard-no-sound-out-fuxmm42irvf2p03kxwfdv02c-5-6.jpgParts that might be damaged in case of no-audio are:
IC 2,4,5 (4570), IC9 (78L05), IC6 (PCM69AU), IC 3 (5216).
Check also the transistors Q1-Q7 (This is the MUTE transistor, and this is most often the cause in case of no-audio).
If you can not fix it by yourself, then leave it to the experts.
Sep 06, 2014 • Korg Music
1helpful
My gf has a roland hp1500 digital piano but the pedals arnt working. Im trying to fix it while she is away. I am a security engineer and have access to and can use a test meter amd am confident about...
I you mean the sustain type pedals, FIRST check the connector(s) as they often come loose or unseated. Next check for a broken pin in the connectors. It is UNLIKELY you could troubleshoot anything inside with just a meter. It appears that some of the Roland pedals receive 5 volts in the connector, and upon contact closure the voltage is sent back to the piano where it drives C4570 buffers with 680K to ground and an RF bypass cap and series 330 ohm to the + of the C4570's. The circuit I have is for a different piano but if yours uses the 8 pin connector it is likely the same.
The contact is actually optical interrupter modules with a driver transistor. There are threshold setting pots in the pedal assembly as well. The farthest I would suggest you go is to make sure the optical interrupter modules are free of dust if this is the type you have,.
May 28, 2011 • Music
1helpful
2answers
I have this problem. my bass amp is blowing fuses SWR workingman4004 the problem is that not only burns but also fuses the 4 output transistors (2sc3264) and a resistance R22, and replace them when I was...
I don't have a exact schematic for your amp, but I can give you some hints and suggestions...
USUALLY when the output transistors fuse there is a problem at least one level back and sometimes two levels. Often the driver transistors also get fried and sometimes one stage farther where the bias is regulated for the final amp transistors. A schematic is imperative to diagnose and repair unless one replaces every part.
Next, to prevent damage when restarting the amp, put a 100 Watt incandescent lamp in series with the hot power into the unit. This acts as a current limiter and auto-resetting fuse. The lamp will come on and limit the current while one troubleshoots the amp to find what is causing the current drain.
This schematic MIGHT be pretty close to your unit:
http://elektrotanya.com/swr_swr2000_power_amp_module_sch.pdf/download.html
I would expect to see Q4 through Q12 destroyed and maybe a few more components. If transistor Q4 opens, goodbye all the transistors! The 1N4004 diodes are PROBABLY big enough to take it, but all the small transistors probably are damaged or degraded... The high value resistors will survive, but the low ohm ones that can draw enough current may be damaged.
Try to analyze what each part of the circuit is for... I think Q13 and Q14 are part of a soft start circuit. This amp is NOT well protected in case of component failure and MANY that fail in the final stages cause catastrophic destruction.
Use my suggestion for the lamp. Often using a Variac to slowly bring up the voltage is handy, but one doesn't only have one available.
Mar 04, 2011 • SWR Music
1helpful
2answers
I have a Pmp5000 889406987784 Eurowpower PMP5000 1200-Watt 20-Channel Mixer and Speaker Output A has no output. What has happened?
Usual problem is the Channel A amplifier has burned and blown the switching transistors. Usually an internal board arc occurs and unless very skilled at board work of clearing the burned area and replacing the components you are better to replace the HCA2400 amplifier module... about $160
Last weekend while I was playing, I smelled that smell. After I turned my 800RB bass amp off I saw smoke coming out of the foot switch input so I hooked up my spare amp. When I took the amp apart I found...
They are NOT called motherboards, just circuit boards.
Sometimes the board can be restored by carving out the black and re-insulating it and repairing the cause and bad components.
Likely the power transistors have shorted that are associated with that side and burned compnents.
Many shops will only replace the whole board rather than do the labor to restore the board... Yes, either way it will be expensive to repair.
Causes of these failures can be overdriving the amp. bad speakers and or cables. Loose speaker connectors that vibrate can lead to this.
Another problem can be if SUPERSONIC (can't hear it) feedback is occuring at high frequencies that overloads the amp.
1helpful
I have Behringer pmp 2000 mixer but it burned my fuse. How can I buy it?
If the fuse blew do NOT replace it till the unit is serviced or you will burn up more components. These units will blow out from a minimum of three to 30 components when they blow.
There is weak insulation between layers of the power amp circuit board and the arcing destroys a minimum of three transistors and often many more components on the power supply board as well.
I have repaired several of these and it is a lot of work. The power amp module can be had for about $175 but it often takes out the power supply as well.
1helpful
3answers
TRANSISTOR TYPES FOR PEAVEY XR684 MIXER AMPLIFIER/ARRANGEMENT
Go to Peavey's website
http://www.peavey.com
You may find what you are looking for here if not you may have to call them.
Top Vestax Music Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Vestax Music Expert? Answer questions, earn points and help others
