Please check the hard drive . Seems the hdd is having bad sectors.
Run a scan on your Hard Drive, It seem to me issue with the HDD.
Thanks
Kevin
Hi
You need to stay calm and check all the wire of the computer.Just check that all the cables are properly plugged in.If still it doesn't work then you must use recovery disk.
You need to replace the mother board or hard drive and thats really expensive to do. You are better off buying a new PC. Syick it as faulty on ebay to gain a bit of cash.
Applies to: Microsoft Windows NT, Windows 2000, Windows XP
SymptomsWhen you start your computer, you receive the error message "NTLDR is missing. Press any key to restart."
CauseThe error message "NTLDR is missing" means that the Windows boot loader (NT Loader, NTLDR) cannot be found. This oftenoccurs when the computer tries to boot from a drive other than the one Windows is installed on, due to a change in the driveconfiguration or because you left a bootable disk in a removable drive. But it may also be because the NTLDR file has beencorrupted or deleted.
SolutionCheck the boot drivesFirst, check the boot drives to make sure that the computer is not trying to boot from a different drive to the one thatcontains Windows.
If this does not resolve the problem, you will have to repair the NT boot loader.
Fix NTLDRThe easiest way to fix the "NTLDR is missing" error is to use Spotmau PowerSuite.However, if your computer is using Windows XP and you have a Windows XP installation CD you may be able to boot from this anduse the Recovery Console to fix NTLDR manually instead.
Use Spotmau PowerSuiteInsert the Spotmau PowerSuite CD and start the computer. The main menu will appear.The tool will repair the file and report "NTLDR and NTDETECT have been recovered successfully."
Below are the full error messages that may be seen when the computer is booting.
NTLDR is Missing
Boot: Couldn't find NTLDR
Please insert another disk
NTLDR is missing
Press Ctrl Alt Del to Restart
Causes:
