Question about Master Lock TSA Set your Combination Lock With Instant Alert 4687DNKL Pack of 4
I forgotten my skybag number lock how to open the lock .
Posted by Sooraj Umarani on
ka4iup
  • 4,062 Answers
You can try to determine the combination by pulling on the shackle and moving the combination wheels until one of them clicks (or feels) different from the other numbers. Do the same for the other two number wheels. Lots of trial and error, but it has worked before.
http://traveltips.usatoday.com/unlock-threedigit-combo-master-luggage-lock-109482.html
Posted on Feb 05, 2015
I have forgotten the digital number of my luggage lock -Eminent brand. How to unlock it ?
Yoong queen,
You can able to open this number lock, but you show more patience,
put the lock number to 000 or 0000, then start with 001,002,,,upto 999 or 9999 if it is fourth digit. Each time you every digit give a slight pressure to the lever,,it will open with the correct number and open with that number you forget.
with regards
jaijith
Jun 02, 2017 | Luggage & Travel
Says code error
How To: Open A Locked Sentry Safe If You Forgot ...
? 5:21
https://www.youtube.com/watch?v=Mr8QrvVAtuI
Jul 15, 2014 - Uploaded by TipsNNTricks
I show you How To Open A Locked Sentry Safe If You ForgotThe Combination Or Loss Your Digital Code Or Lossed Your Key. The Sentry Safe ...
' Sentry® Safe ' Lost Your Combination
https://www.sentrysafe.com/.../Lost_Your_Combination
Sentry GroupCombo Recovery. What you'll need: Model Number; Safe Serial Number; Notarized Statement of Ownership. Step 1. Safe Info. Step 2. Notary Form. Step 3
opening a electronic safe forgotten the lock code ready to ...
www.instructables.com/.../OPENING-A-ELECTRONIC-SAF...
InstructablesJul 6, 2009 - I HAVE A SAFE GAURD COMPANIES SAFE I HAVE FORGOTTEN THE LOCK CODE TO OPEN IT. THEIR IS NO ALTERNATIVE OF KEY ...
How to Crack a Safe (with Pictures) - wikiHow
Jan 10, 2016 | Home Security
I forgotten samsonite lock number. how open lock
I am sorry to say that if you don't know and cant afford to try the numbers in turn, you are stuck needing another way to get in.
Apr 20, 2015 | Samsonite Photography
Luggage number lock
I have forgotten the number lock code on my hard shell equator suitcase and can't get it opened. how do I rectify this.
Jul 21, 2013 | Luggage & Travel
How to open the combination
If you have forgotten your code then you have to try go through one number at a time and get it that way or just cut it off and buy a key lock
Jun 13, 2013 | Bell Cycling
I 've got one of the american tourister suitcase, packed my stuff in and was trying to weigh but couldn't get it open and have forgotten the combi lock.
if you have forgotten the combo then the only way to get the lock open is to 'progress' the combo.
start at 000 - try the latch, then go to 001 - and try the latch, then to 002,003,004,005,006,007 etc... trying the latch at every number,, keep going through the numbers until the lock finally opens with the right combo --- this should only take you about 15 to 20 minutes to figure out the combo since I am sure you will not make it all the way to 999 -- what will help the speed of this progression is if you can remember at least one of the numbers.
c...
Jan 26, 2011 | Kitchen Ranges
I baught a new Skybag (product of VIP Industriers in India) and set the number lock to my preffered 3 digit nos.On reaching Melbourne from Delhi,I am unable to open my Skybag number lock.Can you please...
well -- if it is not opening with the digits that you have selected then something may have gone wrong in the lock itself or broke. one thing that you can try is to see if the combo somehow changed due to a faulty disk is to progess the entire combo pack,, by this I mean starting at 000 then 001 -002 -003-004 and so on all the way up to 999,, and after each new number is dialed in try the lock. back in the lock shop I worked at we would get one or two of these a week and it should only take you about 15 to 20 minutes to go through the 1000 numbers. ( hopefully you will get the combo sooner ). now there is a chance that the lock catch is just bound up and if you put in the digits that you picked and press down on the lock latch and try and release it then with the lever - this might snap it back. if both these suggestions fail your next bet is to find a local locksmith and see if they can read the wheels and line things up right and get the lock to open,, most shops will only charge 5 to 10 dollars for this service.
I hope it all works out,
c...
Jan 01, 2011 | Garden
Number pin lock forgotten
Relax. You just plug the P2 to your pc and open SMS (the program which came with the P2), and open up an application called EMODIO. If you dont have it, you need to upgrade the SMS program. Good luck.
Oct 07, 2008 | Samsung Yepp YP-P2 Digital Media Player
Master Lock TSA Set your Combination Lock With Instant Alert 4687DNKL Pack of 4 Logo
1,753 people viewed this question
Top Master Lock Home Security Experts
ray gallant
john h
Andrew Taylor
Andrew Taylor
Are you a Master Lock Home Security Expert? Answer questions, earn points and help others
