Pentax ME Super 35mm SLR Camera Logo
b
beau atherton Posted on Feb 04, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Pentax ME super and the film door will close when there is no film but when i load it with film its not closing properly?
  • Erin Taylor
    Erin Taylor Feb 05, 2015
    I had this problem when first learning how to use a 35mm SLR. What I found is that if you do not advance the film enough for it to click and lay flat against the shutter opening, my door will not close. You may lose a few frames, but advance the film manually, with the door open, until it lays flat and taught.
  • Erin Taylor
    I have 2 Minolta x700's.
Vernon Taylor
Level 3:
  • Pentax Master 7,446 Answers
  • Posted on Feb 04, 2015
 Vernon Taylor
Pentax Master
Level 3:
Answers
7446
Questions
0
Helped
1960137
Points
26207
I really loved your camera type though it was 35 years ago I had one. I envy you.
Not sure why you should be having trouble unless you have a bad film. Have you tried more than one film?
If the film cassette has dropped in properly and is laying flat, the film rewind has to be raised, I think, to allow that and the sprocket holes in the film are properly engaged with the sprockets and the free end of the film engaged onto the film wind-on reel then everything should be well below the door aperture.
I would wind on maybe a frame and fire the shutter prior to closing the film door just to observe everything moving as it should and then close the door.
The last quarter inch the door must be closed against the pressure of a spring but if the little spring-loaded device behind the door which is intended to keep the film perfectly flat against the camera body is working correctly only a light pressure will be needed to compress those springs and close the door.
Perhaps something is wrong there?
I don't remember any problems closing the film door.
I hope this helps but if it doesn't please come back again and describe your actions and the feel of the door more fully.
Pentax ME super advance film doesn't get caught
This is a known fault with this retro model, I'm afraid - over time, the plastic gears get worn, and eventually fail. Solutions are mentioned on the Pentax Forums.
My Pentax SPII shoots blank images
You can check the shutter without film in the camera. Remove the lens and open the film door. You will see the cloth curtains of the shutter in the center. Advance the film lever to **** the shutter and set the speed dial to a slower speed like 1/15. Hold the camera so it is aimed a a light source, (a window will do) and fire the shutter. You should see the light through the shutter for the time duration is is set to. (1/15). If you see the light source, repeat the process going up one speed setting until you reach 1/1000. If you see the shutter open and close as described, then try another roll. After you load the film and close the back door, make note of what the rewind knob is doing as you advance the film. It should spin counter-clockwise each time. That is a easy test to know that the film is traveling in the camera properly. Vary your exposures with the new roll at different speeds and f-stops. You should get exposures, but if not let us know.
3helpful
Pentax ME wider II problem
It should stop advancing the film when the camera counter is on #1 exposure with or without film.
2answers
I have no idea how to put my film in the "Pentax mz-m" camera? Someone help me. I'm new to this as I am just doing photography at school!
Pull up on the rewind knob ( left side ) to open the film door. put film cassette in chamber then lower rewind knob and pull enough film leader to the take up spool. attach film to spool. close the film door then advance the film to #1 on the counter.
4helpful
Film won't advance
Pentax ME Super was one of my favorite camera, small and clean shutter release. But it has been about 25 years since it was manufactured. They happen to use rubber break within shutter unit and as any rubbers, it started to deteriorate and melt between the shutter-blades. This prevents the complete cycle of the shutter and jams the winding. You may be able to unjam the winding but eventually you have to overhaul the shutter unit. Overhaul charge is around $100 in US repair market. -James
My film won't load
Jammed Advance Motor Assembly.
1helpful
2answers
How to replace back ''door'' on Pentax ME super
No, you won't. Open the back and look at the hinge of the film door. There is a small screw near the top that sticks out. push it down with your finger to release the upper door pin. Your light leak is likely coming from that area too. A bad seal on the hinge is the usual suspect.
1helpful
2answers
Loading film in my vintage camera..help!
The "magic needles" while making the camera easy to load are about as intuitive as a dead skunk, I had a similar confusion when I got an ME Super. Put the film can in the left side of the camera back (the side with the little thing sticking out is the bottom, it looks upside down this way, but that is correct). Next push the film winder down, this will semi-lock the can into place. Now pull the film-lead across the camera and push it down between some of the white "magic needles on the opposite spool(push it in a bit so that it will stay). Next advance the lever; release the shutter. If the spool starts to turn you are doing it right. Now close the door and continue advancing and clicking until the little frame number window on top reads 1.
Film counter does not advance when film is wound forward!
The frame counter is engaged when the film door is closed by a small tab at the top of the door near the hinge. Try pressing that area of the door as you advance the wind lever. You don't need film in the camera to do this. The counter with work without it. The door may be a little bent and not pressing the counter lever in far enough to fully engage the mechanism.
Pentax ME
A simple fix might be to borrow a page from movie cameramen. Tape it shut with some black hockey tape. I was considering doing this eventhough my ME Super works fine. If you think that looks too getto, then it sounds like a service repair shop is the other answer.
Top Pentax Photography Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Pentax Photography Expert? Answer questions, earn points and help others
