POWER OFF/ SHUTDOWN
System turns on then the display says poweroff , this takes about 4 secs then the system shuts down,,,
  • 20 more comments
  • Kbottineau Nov 20, 2007
    I am having the same prolem what is the solution?
  • goodsam Nov 22, 2007
    mine will come on for a few seconds showing the volume level then after 4 seconds or so it will shut off with out warning....seems like a common problem im thinking it might have something to do with the common overheating problem of this receiver....
  • Anonymous Jan 11, 2008
    I have the same problem. It has been occurring since I purchased the unit but BestBuy disavows any knowledge of the problem. Speakers are all new and sufficiently large, wiring all tested.
    Sometimes the problem occurs within seconds, sometimes an hour and a half into a DVD. Resetting has no effect. Once it turns off, it will continuously turn off each time I try to turn it on again. This problem is MADDENING!
    Anyone know of a solution?
  • fuus Feb 01, 2008
    I have the same poweroff message and the system shuts down. what might the solution be to this problem?
    This happened after my baby turned up the volume and it shut off. Does it have any thing to do with the circuit?
  • Anonymous Feb 21, 2008
    I tested the wires it did not correct the problem please help!!!!!
  • sleeprboy Feb 23, 2008
    I have the same problem. I like to watch my movies loud. Everytime I
    turn up the volume past 12.5db, the receiver shuts off and goes into a standby mode. It will come back on, but you have to turn down the volume to keep it on.
  • Anonymous Mar 21, 2008
    I also have the same problem.
  • andcar Mar 24, 2008
    I do have the same problem and guess the couple capacitors too old, but not sure... it needs to be checked out...
  • may12345 May 10, 2008
    my receiver will not stay on
  • walker001 May 15, 2008
    i have the same problem. if i turn the volume up past 12db it shuts off, please help
  • sam pomery Jun 14, 2008
    yes mine is similar
    it tunes on for 5 sec .
    in that 5 sec . start up it gets to receiver on the display
    it shuts off and Power indicator starts fashion red to green
    iv disconcerted every thing and shut it down. it still dose it.
    it was a result from haven it up to loud for to long . i think
    please solve me problem as i Cant afford to take to a shop, i spent all my savings two days ago payin for it
    ill try the Miltimater thing while i waiting for your reply
    thanks in advance sam
  • Anonymous Jun 17, 2008
    Mine is doing the same thing. On for about 30min then shuts off.
  • texnhawk Jul 10, 2008
    My receiver turns on then shuts down completely after 5 seconds. It was working fine and I don't believe had been run too loud. It was outside and possibly overheated or might have gotten some dirt on a chip. I did blow off any dust and it didn't help.
  • Anonymous Jul 30, 2008
    power off
  • Anonymous Aug 04, 2008
    My T773 will go into shutdown mode after getting warm (averages about 30 minutes). I had this problem a year ago and took it to a local authorized repair center. They said there were many cracked solder joints on the power supply board and replaced a filter capacitor. The problem didn't reappear until about a month ago.
    I would never, repeat never, buy another NAD product. I spend $1500 on this receiver.
  • claurenc
    claurenc Aug 16, 2008
    My Harmon-Kardon AVR520 shuts down at random times. It did this when I first had it, then it quit for years, and now it's back again. I have done two recommended resets, unplug for 30 min and restart, reset all the memory using two console buttons. It doesn't shut down as often now but still eventually shuts down.
  • Anonymous Aug 22, 2008
    my receiver just turns off after like 5 seconds idk what to do need help
  • Anonymous Aug 25, 2008
    i turn on me receiver and it turns off in 4sec
  • mjringwn Jan 08, 2009
    i have a vsx-d307 pioneer receiver that is doing the same thing.turns on then powers of.help!!!!
  • abbaja1672 Jan 28, 2009
    powers on for three seconds and then shuts off.
  • fgisiner1 Jan 31, 2009
    GOOD LUCK ON GETTING ANY ASSISTANCE FOR THIS PROBLEM [SPECIFIC TO THE DENON DRA/395] DENON LISTED SERVICE CENTERS ARE NOT INTERESTED
    Sub-Note THIS UNIT HAS SPEAKER OVER LOAD PROTECTION CIRCUITY [They say] BUT THIS IS THE WAY IT ACTS/ AN OVERLOAD AT SOME POINT IS NOW CAUSING IT TO SHUT DOWN AFTER POWER UP
  • Anonymous Feb 19, 2009
    my pioneer vsx-d5o9s reciever i turn it on and the screen flashes power off and it shuts off
Anonymous
I found the solution for me! I had the problem where after 1-5 seconds, my receiver would simply shut down. Twice now I've solved it.
The problem is most likely that you have speaker wire that is touching the opposite terminal or coming close to doing so. Check all your speaker wire terminals and make sure that they are not touching at all or coming close.
Also, make sure that your speaker wires are truly in speakers. If you have speakers plugged into the back of your receiver and then sitting out on the other end, that could be the problem as well.
I hope that helps - it solved it for me!
Posted on Aug 07, 2008
Anonymous
Ok my did the same and i didn't know what to do.well ask the old man he told me try in blowing the inside out with like an air compresser
Posted on Jan 09, 2009
Anonymous
I had wires on a speaker that were touching.  Once I corrected this the power stayed on.
Posted on Jan 22, 2008
1 Related Answer
Anonymous
  • 271 Answers
SOURCE: POWER OFF/ SHUTDOWN
Hi,,,thanks for your good response...Understnding a 7.i surround system through chat is difficult...that ws why i couldnt get it right...if i was there at your place i would have solve that it in seconds...anyway you got it done by yourself thats what we wanted...thanks again
Posted on May 26, 2008
My friend kept turning it up and i kept turning it back down then it just said poweroff
Sounds like your "friend" has cooked something. It could be one of your speakers (do they all sound ok for the 5 seconds it runs?), or it could be the receiver....
I would try disconnecting all the speakers and see if it stays on. If so, it may be one of the speakers. Connect them one at a time, and see if you can tell.
Nov 10, 2015 | Pioneer VSX-D308 Receiver
After turning on my reciever i get a flashing poweroff on the display. unit then shuts down
check your speaker connection. if that doesn't work check your fuse to make sure it's good.
Mar 03, 2011 | Pioneer VSX-D510 Receiver
Protron tv 3250 tv went off. only blue light blinks
Your TV has two poweroff functionalities. First power off button is on saver mode least displaying any transmitter programs. Using the remote control to power off the device achieves screen saver poweroff mode. Second manually pressing on the power button after power saver mode has been achieved with the remote control device should shut down the TV tube entirely. The blue light should not display in whihc instance. Howerever, a full power off mode is incapable of being controlled by the remote control device whenver poweron is required later. The TV power shut down button has to be pressed again to alow for current circulation once more. Powering off the TV with the button on the set requiries momentary duration waits whenever to achieve display of signals depending on the size of the TV, and how many pheriperal device connnections are attahced to it.
refer to the TV user manual for possible diagnostic to any persistant conditions.
Good luck
Jan 08, 2011 | Protron PLTV3250 32 in. LCD Television
System shuts down automatically
Remove the battery and adapter. Press power button for 30 sec. Then connect the adapter. Press power button. When pc started, go to
control panel---->power options--->change plan setting--->
Turn off the display-never
Put the computer to sleep-never
control panel---->power options--->change plan setting--->advanced power setting
-set hard disk "turn off hard disk after" to never
-set Sleep "Sleep after" to never
-set hybrid sleep setting to off
-set hibernate after setting to never
Restart pc
Apr 12, 2010 | Lenovo 3000 Y410 Laptop
VSX-D457 Display's power off and then shutdown
Most likely it needs one of the output ICs. But check for cold solder rings on the ground connections of the input board. Est. for it to be repaired $100-$120
Dec 17, 2009 | Pioneer VSX-D457 Receiver
I made some changes in Engineer menu of my sigmatel s4 mobile.
I m having sigmatel s4 mobile. I made some changes in Engineer menu. I have actually turned on high speed dual sim mode. after that poweroff in 3 sec display message come and till now it has not started. tell me how to rectify it. Also i don't know how to rectify it.
Sep 22, 2009 | Lands Phones
Sigmatel s4 is not starting
A Sigmatel S4 is a kind of cell phone dude.
1 - Get the manual for it.
2 - Read the manual for it.
3 - Take the battery out of it, wait 10 minutes, put the battery back in and start from scratch setting things the way you want them to be.
4 - If none of that works take the phone to your provider and get them to fix it or trade it for a not broken one.
Carl
Oct 17, 2008 | Welding Tools
POWER OFF/ SHUTDOWN
May 25, 2008 | Denon AVR-1905 Receiver
Proview Pl926wbi
This is an inverter board problem. The inverter supplies the high voltage and frequency to run the CCFL backlights. The board has a sensing circuit to shut down the output if too much current is going to the backlights or it will shut down if the transistors overheat. I have replaced transistors on some boards with higher rated transistors and they have worked great for years. Sometimes it is just a cold solder joint on the inverter board. Replacement boards are expensive but not too difficult to replace. Repair requires some ability with electronic boards and should not be attempted if you do not posess the skill. You could end up damging other parts that cost more.
Jan 18, 2008 | Proview PL926WBi 19" LCD Monitor
My computer shuts down after 3 secs
Try to separate the power cord of your monitor from your system or maybe if your using UPS(uninterrupted power supply) directly plug the UPS to the wall outlet. either you can use pretty voltage regulator to the regulate the AC power.
if not solve the problem try to examine the your system power supply.
Dec 11, 2007 | Computers & Internet
1,191 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
