When air is turned on the fan does not work, but get cold air is this normal?
The blower, , does it spin and make noise?, like normal blower
and blows air. (if not , does it blow in any modes, of controls)
the post contradicts, you said, "it blows cold air" is that moving ca. no not?
if moving all cars blow air, due to car moving (stick and out window feel that air)
but parked that job is the BLower fan. you can hear it run.
is it SILENT?
if yes, check fuses. first.
always.
what is an X4 (SX4)
dead blower, parked, in all modes. is:
1: blown fuse.
2: bad controls to blower.
3: bad blower
4: bad wires to any and all of that (yes, connectors too)
to find cause, takes checking fuses.
then if all measure 12vdc both sides,(blower fuses)
then we use same meter to find if 12vdc makes it to Blower.
and work that problem. as the case my be..... easy peasy
Not sure which fan you mean. Engine cooling fan is different from heat/air blower fan.
Testimonial: "the heat / air blower fan"
