The post imade yesterday i was refering to a honeywell central heating room stat NOT a microwave ..dont know how that pic got there.!! how do i reset the dial so its in the correct position ..its working now but not as it was before..
It is a thermostat, you are showing here. The thermostat can be defect, when it does not switch on the correct temperature. But when the 3 wires I see are the only ones, connected to the system, I wonder it could work at all.
Is this in the Netherlands?
SOURCE: Honeywell Central Heating temperature control
R comonY cool W heat G fan C other side of 24 unless you are battery operated. On the back of the Tstat tou should have switch that says gas or electric this controls how the fan operates. If not go into programing and program 1 stage heat one stage cool.Let me know I will walk you thru this.
SOURCE: how do i change an old style honeywell room stat
Shut the furnace off for starters. Remove the old Thermostat. As you remove each wire write down what terminal it wen to.
Example:
Red wire usually goes to R-Power
Green Wire usually goes to G-Fan
White usually goes to W-Heat
Blue or Yellow usually goes to Y-Cool
SOURCE: wiring of gas central heating
you have a link pin on 3-4 or 1-5 or seperate 2 pin connector,thats were the stat goes,any way round with wires
SOURCE: boiler is a baxi control for heating is honeywell.
this will be your diaphram inside your divertor valve.
the one that looks like a spaceship.
it will e split.
SOURCE: Central heating - room thermostat Honeywell T6360B
hI he has wired the pump to permanant live there should be link between two of them ? cannot recall which . not much help sorry
