No singular answer. Here are some of the things to try, following by links depicting details: 1) Update audio drivers via device manager or 3rd party ware 2) Change sound quality by altering Speaker properties via Sound icon on task bar 3) Change Loudness Equalization of Speakers in Enhancement tab of Speaker Properties 4) Run Audio Troubleshooter 5) Use Windows Volume Mixer to increase sound 6) In Sound, change Communications tab to Do Nothing 7) Try different audio device 8) Try VLC and adjust it to boost volume 9) In Chrome, use Volume Boosting extension 10) Clean speakers 11) Increase Media Player sound
Check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience. http://electro-medical.blogspot.com/ http://electronicshelponline.blogspot.com/
If the original recording is on low volume then you will get louder sound on the player device while if the recording is at high volume the you get low levels on player. try recording at lower volume settings on the phone. Then when you play it it will sound louder on increased volume.
Hi Ashlee, Is it the overall volume or is it an individual Application that has low volume? The volume control in the menu bar shows the whole system volume but many apps have their own volume controls - and if they are set low then turning up the system volume will have no effect.
Your volume limit on your ipod is probably set low. To check it, go all of the way to the ipod's main menu and go to settings. Then go to volume limit and put it where you would like it to be if it is too low. Then go back to your music and play it. Turn the volume up to your liking and it should work and play louder.
not at all ,On your ipod there is a volume CONTROLL LIMITER so look for that feature on the ipod and u would see that it is low and it possible that u can raise the volume.
