DVD's in any of the five changers will play a little and then freeze for 2 - 5 minutes and then plays a little more (10 - 30 sec.) and freezes again, over and over. Picture is clear though.
This could be from a number of issues. first is it a home made disk? second the type of changer you are using?
home made disks can be fixed by using a + or - disk depending on the disk and what the drive likes.
as for the second issue it could be a cooling issue or the lens might be dirty try blowing it out with some can air and try to use a lens cleaner disk. they should be able to sell one for about $5 - $10
Troubleshooting Solution
available parts avsystemparts.com
1. Possible Problem w/ Main Board PCB
2. The dive laser assy replace. or full complete 5 Disk changer ROM
3.More chance problem w/ Main Board
4. Problem w/Main board need replace it.
Thank you. I will try to clean the lens. It is not a homemade disc... I've tried all kinds of discs. The player has DivX, but I tried different kinds just in case.
Thank you again for your help.
