Bought used scanner / copier, unknown admin password, need to change IP address. Need default administrator super code to bypass unknown admin password.
Mr. Gates, yes there is away to change the pw recommended you get a tech out to do it. Change admin pw not over the internet. Should have a paper work to back it up. Big time security thing Hard drive access and stuff
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Problem in configuring IP address in Konica Minolta bizhub 210 Copier, Printer, Fax
Is there network card is installed in it, if yes then you can configure it with your network go to machine Manu in machine control panel and the in network settings here you can give the IP address and subnet mask after then reboot the machine.
If network card is no installed behind the machine then you can use its built-in USB or and parallel printer without NIC card.
SOURCE: I need the default ip address for the Konica Minolta C350
Press the Utility/Counter button.
Administrator Settings - password is 12345678
Network settings
TCP/IP settings
SOURCE: Konica 7022 - Need to change login password
Hello sir; Go to set up your own password then you can use it, hold down 2 & 5 while you turn power on, then pick up password set, follow the direction to finish,then turn power off.
SOURCE: Konica Minolta Bizhub 350
You are getting a failure sheet. This happens when the scan doesnt go through. I think you are reffering to SMB scanning, which needs to have the following setup on both the MFP and the copier.
Host ID or NAME - IP address or hostname with DNS resolution.
Share Name - This is your SMB share name or folder share name on the remote PC
User Name - This is an account that is configured on the remote PC
Password - This is the password for the account setup on the remote PC.
Some things to keep in mind: Third party firewalls can block the bizhub from writing files.
Set share permissions to full control. (under sharing tab> permissions buttion)
Set NTFS permissions to at least write access. (if you have a "security" tab on the shared folder.
Or, you may see something like "allow network users to change my files" on the sharing tab. This basically does the same under different configuration scenario.
One last thing. If you havent changed anything since the problem started, it is probably just something like an expired password on the account that is setup for the copier.
Good Luck.
