Question about Kyocera FS Office Equipment & Supplies
How do i clean Kyocera 220 drum unit
Cleaning with cloth
Posted by Bateiboklang... on
Asghar Nadeem
    Champion:
    New Friend:
  • 245 Answers
Cleaning with cloth and brasso
Posted on Jul 08, 2015
5 Related Answers
Anonymous
  • 22 Answers
SOURCE: How to save drum unit encrusted with ink?
A little denatured alcohol and soft cloth is ok. Water is a no-no. The wiper blade may be defective on the drum unit and or the excess toner cavity in the rear of the drum may be full. Best bet is to replace the drum.
Posted on Nov 19, 2009
fivemayur
Sanjay Parihar
  • 414 Answers
SOURCE: How to clean risograph drums?
replace drum
Posted on Sep 01, 2012
Tumaini Kihampa
  • 67 Answers
SOURCE: Hi, just wanting to know
open 2 screws at the top cover remove the cover take a soft wipe comes with the unit or any soft clothe and wipe gentle
Posted on Oct 18, 2012
SOURCE: How To Replace Kyocera Taskalfa 180 Copier Drum
Hopefully this will help.
Source:
http://www.manualowl.com/m/Kyocera/TASKalfa-180/Manual/345566
Posted on Dec 30, 2013
Testimonial: "operation guide will not show the way of replacing drum..."
firecontrol7
Norman J Weimar Jr
  • 6960 Answers
SOURCE: How do I clean corona units on Minolta 1081 copier?
Gregory, First remove the drum unit. Then remove the Charge unit. located about the drum on the drum cartridge (Not Inside the Machine) Then remove scortron grid push the front in to release you then have access to the charge wire this model may have the Charge comb type be care the combs are sharp if they are wires be gentle and use a eraser to gentle clean the wires they are very thin. During the copy process the wire/comb applies a HV charge on the drum prior to the image from the mirrors being place on the drum before the paper arrives underneath the drum.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jan 03, 2015
How should we clean our TV screen from finger prints?
To clean your TV correctly, follow these steps:
  1. Turn the LED TV off, let it cool for a few minutes, and then unplug the TV.
  2. Clean the frame of your LED TV with a microfiber cleaning cloth.
  3. To clean the screen, first try wiping gently with the microfiber cleaning cloth. If that does not work, spray luke-warm water directly onto the microfiber cleaning cloth. Never spray anything directly onto your TV screen.
  4. Wipe the screen with the microfiber cleaning cloth as gently as possible. LED TV screens are fragile and can be damaged if you press too hard.
  5. Let the screen dry completely before you plug the TV back in.
Jan 11, 2018 | Televison & Video
Clothes not getting clean
dryers only dry.............washers get clothes clean...
cheers
Sep 07, 2014 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Dirt in the lens of my panasonic DMC ZS3
I recommend buy a Cleaning lens kit to better cleaning
Kit contains: Cleaning cloth + cleaning fluid
If you have not the Kit cleaning.
Turn ON the camera
Using a soft cloth (If you can use a lens cleaning cloth) add five drops on cloth
Softly rub the cloth on the lens
using other dry cloth, softly dry the lens
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 22, 2011 | Panasonic Cameras
How do I clean the TV screen?
Pleadge has a new product out that is just for cleaning electronics like tv and computer screens. it works great
May 08, 2011 | Samsung Televison & Video
What do i clean the screen with?
Cleaning is simple. Vacuum the rear vents to remove any dust that has built up.
For screen and the fascia, -
1. Unplug the monitor from the power supply.
2. Fill a bowl with warm water with some washing up liquid - just as you would to clean dirty dishes. Soak a soft clean cloth in the water (Kitchen cloth - NONE ABRASIVE!! and not a sponge!), and wring the cloth out so that it is damp (not wet!) and gently wash the screen. When finished use kitchen roll to dry off the monitor.
3. Stubborn marks on the LCD, using the same damp cloth, apply a spot of neat washing up liquid to the cloth. Clean as before - DO NOT PRESS on screen. When finished, use kitchen roll as before.
Voila!
May 14, 2010 | Acer 22" X223w LCD Monitor
It is sticky and looks like glue.It looks gooey
Hello :
Here I'm going to tell you the basics of cleaning your Rowenta iron :
Things You'll Need:1:Rowenta Soleplate Cleaning Kit
2: Ironing board
3:Clean, dry cloth
4:Two cotton terry cloths, such as washcloths
Now to the cleaning :
1:Pour out any water from the iron. Turn the steam iron on to the "Cotton" setting, which is the one with three dots on the settings dial.
2:Cover an area of the ironing board with a clean, dry cloth. Fold one washcloth or other piece of cotton terry cloth in half and place it onto the cloth on the ironing board.
3:Dispense a 2-inch long daub of cleaning solution onto the terry cloth. Run the heated iron over the cloth directly on the cleaning solution. Move the steam iron in a circular motion over the cleaner on the cloth for a minute or two.
4:Remove the steam iron from the cloth. Carefully wipe any remaining cleaning solution from the soleplate using the second terry cloth.
5:Add water to the steam iron. Turn on the "Steam" or "Burst of Steam" feature. Run the iron over the clean, dry cloth on the ironing board to ensure the cleaning product is entirely gone from the soleplate.
PLEASE RATE !
Apr 20, 2010 | Rowenta DX6700 Iron
How should I clean it
You should use a dry, soft, non-static cloth to remove dust from the screen. And, YES, the unit should be turned off before you clean it. Halos are usually caused by pressing too hard on the flexible screen covering when cleaning or by static electricity (VERY BAD!!) from your cloth.
If you should ever need to clean the screen more thoroughly than a dry cloth will do, dampen your cloth with clean water and wring out completely (the cloth should only feel damp...not wet) and use that to clean the screen. NEVER use any sort of household cleaner on the screen, such as ammonia, liquid glass cleaners, or detergents. The screens are tough but more liable to become damaged through incorrect cleaning.
Dec 01, 2009 | Vizio L37 Television
Seems to take picture then turns off, and can`t review
This is just a guess from out in left field but are you sure your battery(ies) is charged up -and that it hasn't lived out its lifespan? Also clean any battery contacts with a clean, lint-free soft cloth or a clean pencil eraser followed by the cloth.
If you use AA batteries and they have leaked, you will need to clean the electrical contacts in the camera. Use a clean, lint-free cloth, dampened only with water- you don't want moisture getting into the camera. Use your finger and the damp cloth to clean ayway the corrosion. You may need to rinse and repeat with the cloth a few times. Then use a dry cloth on the contacts. Leave the battery compartment open for an hour then try new batteries.
Feb 22, 2009 | Kodak EasyShare CX7430 Digital Camera
Whirlpool Cabrio washer not getting clothes clean
hi there,
there are 2 reason for not getting clothes clean:
1) water supply
if you don't have enough incoming water, the clothes will not get clean and you'll have detergent residue left on your clothes
2) detergent
you have to use the He detergent for the best results
Oct 03, 2008 | Washing Machines
133 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Kyocera HP Expert
Marvin
Marvin
Muntejaya Ginting
Muntejaya Ginting
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
