Question about Tools & Hardware - Others
I have a DeWalt DW733 and I need instructions on how to change the knife blades. Is there a jig or something to set up the blades.
Posted by cevans2686 on
Anonymous
    Problem Solver:
  • 16 Answers
Are the blades turnover knives? If they are the easiest way to do it is to adjust the planer bed or seat to omm planing depth. then take either an adjustable (combination) square or steel rule, and hold the edge of it along the bed or seat and adjust the allen (Hex) screws so that the edge of the knife allows a piece of a4 paper to pass between it and the rule tightly. Do this both sides of the knives and you are done.
Posted on Jul 07, 2009
How do I download dewalt 733 manual?
Try Googling (DeWalt)(733)(manual) without parens.
Apr 27, 2017 | Dewalt Drills
How do you change a jig saw blade
At the front, above the blade, is a finger slot. Insert finger and pull forward. Blade will be released. Insert new T blade and release finger.
Apr 24, 2016 | Dewalt Saws
Dewalt 331k jig saw blade falls out
Dewalt Jig Saw
DeWalt Jig Saw MANUAL ManualsOnline com
Blade catch wears out too fast
I loved this tool when it was working but after not that much use the teeth that hold the blade under pressure no longer hold hard enough to prevent the blade from coming out. The mechanism that holds the blade has no catch hole, it uses a few serated teeth to pressure hold the blade in place. Unfortunately, once the pressure starts to lessen you can't tighten it down...
Aug 24, 2014 | Dewalt 331K 6.5 Amp Top Handle Jig-Saw
I need a copy of the owner's manual for Dewalt's Dw733 power planer...please
Check the planer product label on your DW733. DeWalt has two DW733 (type 1 and type 2) models. The manuals for the DW733 is available on the product page: http://www.dewalt.com/tools-discontinued/machinery-portable-thickness-planers-dw733.aspx . See the drop-down list of documentation on the right side of the page. You'll see a pop-up page with more documentation available on the right side of the page. Scroll down to the Instruction Manual.
I hope this helps.
Dec 13, 2011 | Tools & Hardware - Others
Blade adjustment for dewalt dw733 planer, installed new blades and I have the knife guages that comes with the machine but not sure how to adjust knife blades
go to dewaltservicenet.com and you can download an owners manual with instructions on how to adjust/install the blades.
Jun 14, 2011 | Tools & Hardware - Others
Dewalt DW733 Bench top thickness planer How to change blades ?
OK you need to go to Dewaltservicenet.com and in the middle of the page at the bottom type in your model number it will take you to another page and then find your type number and click on the instruction manual section on the right side, I clicked on type 2. This manual is about 30 pages long. Let me know if you still need help and if I have helped could you please rate the answer accordingly. Good luck
Apr 16, 2009 | Dewalt Tools & Hardware - Others
Help i need to change my Dewalt DW733 Planer Blades i lost manual
try dewaltservicenet.com They have manuals as well as parts breakdowns.
Apr 16, 2009 | Delta TP300 Shopmaster 12-Inch Portable...
Tools & Hardware - Others Logo
386 people viewed this question
Top Tools & Hardware - Others Experts
Marvin
Marvin
john h
Andrew Taylor
Andrew Taylor
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
