Question about Samsung SCX-4725FN All-In-One Laser Printer
My scx-4725fn printer doesn't print. and gives the error message what should i do?
My printer doesn't print and I gives the error message.
Posted by Mary on
Roger Binsfeld
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 133 Answers
What error message shows up? with out that we cant help you.
Posted on Feb 02, 2015
what is the error message that it gives you ? the most common on these printers is the paper feed error the machine will not pick up paper. the feed tire is right below the toner system and the feed tire gets dirty and wont feed paper. if this is the case the feed tire needs to be cleaned. you should take it to a dealer for this cleaning because it is hard to get to the whole tire with out knowing what to do.
Feb 02, 2015 | Samsung SCX-4725FN All-In-One Laser...
Was working fine. Now wont print. IP error?
There are two things possibile, first the waist container is full so you need to empty this.
Second for some reason the printer driver is demaged and you need to replace the driver, now there are two ways to do this, first you use your original printer cd is with the printer at the day of purchase, second you can go to the web; open google and write "samsung printer SCX 4725fn" open the side of samsung and chose the newest print driver version for your printer and download it for installation to your computer; then do the same with the scanner driver and install them both on your computer, now check the funktion.
Apr 11, 2011 | Samsung SCX-4725FN All-In-One Laser...
DOOR OPEN ERROR MESSAGE SHOWING ON SAMSUNG SCX-4725FN PRINTER BUT THE DOOR IS CLOSED
Hi there remove the cartridge and clean the internal part. Then insert the ink cartridge and try. If you face same problem then reset the Printer and turn off for 5 minutes. Now again turn on and let me know the result.
Jan 21, 2011 | Samsung SCX-4725FN All-In-One Laser...
Last page when I print is a blank page with the text EOJ on the top left side. How do I get around that?
I posted this on a separate inquiry, but I feel it benefits to post twice. I deleted all the Samsung SCX 4725fn PCL6 drivers from the computers using the printer and loaded in from Samsung's website a Universal Print Driver. This took care of that pesky EOJ page and the print jobs come out great. Good luck!
Sep 06, 2010 | Samsung SCX-4725FN All-In-One Laser...
Lsu error on SCX-4725FN samsung printer
The Laser Scanner Unit or LSU is what writes to the surface of the drum. The glass above the cartridge inside the machine could be dirty. The mirror motor in the LSU could be bad or needing cleaned so it spins better. The Laser diode could be bad.
Call the ASC, the mainboard is malfuntion and need to be replace.
I hope this helps! :)
May 03, 2010 | Samsung SCX 4200 All-In-One Laser Printer
Printer Samsung - SCX-4725FN. In trying to
you may try uninstall the driver and reinstall the new driver from samsung website. www.samsung.com
it might help to resolved this issue. make sure that after you install the driver do a test print and set the paper size to a4 as default it is set to letter.
May 01, 2010 | Samsung SCX-4725FN All-In-One Laser...
Two Sided Printing for a Mac computer?
I have the same problem with my Canon ImageRunner 3200
Aug 15, 2008 | Samsung SCX-4725FN All-In-One Laser...
Samsung SCX-4725FN All-In-One Laser Printer Logo
85 people viewed this question
Top Samsung Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
