Computers & Internet Logo
A
Abdii Buttaa Baalchaa Posted on Feb 02, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I/O card parity interrupt at F000:F188. Type ( S )hut off NMI, ( R )eboot, other keys to continue This all shows up before I even get the Windows loading screen, so I'm pretty much not past th
I/O card parity interrupt at F000:F188. Type ( S )hut off NMI, ( R )eboot, other keys to continue This all shows up before I even get the Windows loading screen, so I'm pretty much not past the BIOS mode right? Anyways, the main message I'm asking about here is the one with the I/O card. I just provided the rest in case it might help you guys figure out what could be wrong. EDIT: The keyboard doesn't work too. I can't even press the S or R or any keys to execute a command. Thanks again for your time
SirEbrum
Level 2:
New Friend:
  • Expert 57 Answers
  • Posted on Feb 02, 2015
SirEbrum
Expert
Level 2:
New Friend:
Answers
57
Questions
0
Helped
16497
Points
149
Ugly situation, as you're seeing the address range of the I/O card (a BIOS perhaps on a HBA?) and the OS/BIOS is asking you if you'd like to ignore Non Maskable Interrupts. I'd be interested if there are cards that can be removed from slots in the PC first, do so, then see if the PC boots. If you find the PC boots fine without the cards, add them back, one by one until the system stops booting. Also, now would be a great time to clean out the dust/debris inside the chassis, off of the fans, etc.
Wynn Jones
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 115 Answers
Wynn Jones
Expert
Level 2:
New Friend:
Cheetah:
Answers
115
Questions
0
Helped
17150
Points
153
In most pcs you need to repair the start up. You probably have a virus preventing you from doing much of anything. Call the manufacturer and get the recovery key to push when you start it up and wipe it back to the day it came out of the box.
To get around to copy the files off before you do that try this. Press the windows key next to Alt and use the arrows on your keyboard to go up & down & left & right. If nothing happens when you press the windows key, the recover it as soon as possible.
I’m happy to help further over the phone at https://www.6ya.com/expert/wynn_5ba0205233ebfc15
1helpful
I/O card parity interrupt at 6000:27c6 Type ( S )hut off NMI, ( R )eboot, other keys to continue This all shows up before I even get the Windows loading screen, so I'm pretty much not past the BIOS...
look at the pci motherboard add on cards plugged into the motherboard . maybe one of them has gone faulty or is not seated properly in the pci slot.
HOW I RESOLVE THIS PROBLEM, I/O CARD PARITY INTERRUT AT CB00:03A7 TYPE (S)hut off NMI, (R)eboot, other keys to continue
no PC stated (name model) you did post to computers so....
No OS stated (windows 10? Linux, or? )
no options in or on the PC stated, cards present, usb toys connected. etc.
Hi there, my name is Kasu Embaye. I have a problem of I/O card parity interrupt f000:f188 on my dell optiplex 780 computer.so,how to fix this problem? can you help me?
Hi mmm it sounds to me like your motherboard has got some problems. sometimes running system tests through the boot menu may help but should indicate weather you need a new motherboard or not. Sometimes a good clean inside computer is the way to go as well... Hope this helps
Kindest regards
Error I/0 card parity interrupt at F000:F188 Type (S)hutoff NMI (R)eboot, other keys continue
Someone else on fixya suggested RAM - http://www.fixya.com/support/t10259172-o_card_parity_interrupt_f000_f188_type
I'd definitely at least run a RAM test - if you can get that far (bootup using a bootable CD with memtest 4). Otherwise just see if removing the RAM has any impact.
Also could try flashing the BIOS, again if you can get that far.
It's clearly not relating the operating system, so either BIOS, or hardware failure.
Inspiron E1505 will not complete the boot sequence and is stuck on the dell logo screen with error message
Try running the Check Disk Utility.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
1helpful
I/0 card parity interrupt at F000:E1AD. Type (S)hut off NMI, (R)eboot, other keys to continue
This error refers to an expansion card having an issue. If you've got any cardbus, wifi, bluetooth, etc cards take them out and see if that resolves the issue. More info here:
http://www.techsupportforum.com/forums/f217/i-o-card-parity-interrupt-at-f000-e1ad-417586.html
I have a D620 Laptop.. when i turn on my Laptop i get the Eror : "I/O card parityinterrupt at F000:E1B5" Type (S)hut off NMI, (R)eboot, other keys to continue. how can i solve this Problem ...Please Help...
try going into the BIOS of your system upon powering your laptop as soon as you see your Dell Logo keep on tapping f1 till you get a different screen or if the system beeps when you tap on f1 then stop it should boot into your system BIOS and give you options,
normally for dell it should have a phoenix BIOS try setting your bios to defaults then save and exit the bios if still it does not fix you issue then you can try reinstalling windows and its drivers .
Grand Canyon Tech
Grand Canyon Tech
