Question about Sharp Office Equipment & Supplies
I have a photo copier sharp ar-5516 error code U_2 appears copying cannot be done, keys or key pads doesn't work
Key's or key pad not working
Posted by waltermendoza on
prince Henry
    New Friend:
Write your answer...*,#,interupt, C, and enter 16
Posted on Jul 07, 2017
Raj Patel
    Genius:
  • 1,041 Answers
Dryer soft touch key pad not working
re install driver for this key pad
Apr 14, 2014 | HP Computers & Internet
Error code SAb bath on Jenn Air oven. Held clock button down for 5 seconds and key pad still will not work.
possible need new key pad.first check no loose connection from key pad to the control board,if not replace key pad
Nov 24, 2013 | Jenn-Air Ovens
Key pad is not working ...
My Dear Your Phone Key pad IC Fault So Please change Key pad IC
And Key pad Problem will Solved
Nov 28, 2010 | Sony Ericsson Walkman W205 Cell Phone
Nokia e66 keypad is not working
First Try it:
i hope Key pad Problem will Solved
IF Key pad Problem not Solved So
Secend Option:
Please New Software install in the Phone Problem will Solved
Aug 28, 2010 | Nokia E66 Smartphone
Nokia 6070 key pad 3, 6, 9, # key not working i
Sorry to say this please replace keypad crstal IC,and jumper it will work 100% ....reheat the upper components and the the whole pcb,with care,the keypad ic is same as 6600, 6630, n70, 6680, 6280 LCD IC.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
thank you for using fixya have a nice day:-)
Jul 28, 2010 | Nokia 6070 Cellular Phone
N81 8gb,keypad lock switch not working
check kep pad connector
or - chnga ic
Mar 26, 2009 | Nokia N81 Smartphone
Combination on car keypad does not open doors
Does the key pad on the door light up? Are there any tears in the key pad numbers? Does the key pad lock the doors?.
There are no fuses directly for the pad.. The key pad is linked directly to the RAP. module. If the locks work from the FOB the fuses for the Module are good. Chances are the pad is no good especially if it don't light up. The RAP module is above the driver side foot well, directly above the accelerator pedal . Hope this helps.
Mar 09, 2009 | 1999 Ford Taurus
Key pad not working
dust may be accumulated in key pad if u can try opening the panel and cleaning it or the connector of key pad would have failed try changing it
Jan 20, 2009 | Sony Ericsson W200i Cellular Phone
Lg key pad not working
ur key pad domy is damaged so change it quickly
Feb 14, 2008 | LG KG800 Cellular Phone
175 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
