Question about Sharp Office Equipment & Supplies
Sharp ar-5516 code appears u_2
If I turn on the power. code affears and all key pads doesn't work
Posted by waltermendoza on
Norman J Weimar Jr
  • Sharp Master
  • 6,960 Answers
Replace the any and all third party toners and drum replace with OEM
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Feb 01, 2016
5 Related Answers
Andy Bebb
  • 62 Answers
SOURCE: Sharp AR-5127, the error code U2-40
U2-40 is a board error, F1-15 is finisher lift motor error.
To reset: #, interrupt, clear, interrupt. (screen should say service mode), enter 16, print, are you sure? , yes.
For the finisher error, follow above procudure, entering 14 instead of 16. if error returns, disconnect the finisher
Posted on Nov 28, 2008
vinayaka shenoy
  • 32 Answers
SOURCE: h5 erreur sharp AR-5516
if there is a paper jam in the fixing many times this err will be displayed. go to the service mode (C-interrupt- # - interrupt) and enter 14 and then start button.
Posted on Feb 05, 2011
loversboaty2
EKPA ONU
SOLUTION: ERROR MESSAGE U2-40, SHARP COPIER AR-5127
PRESS #
PRESS =
PRESS C
PRESS =
TYPE 16
PRESS ENTER BUTTON (the button for making photocopy)
PRESS 'OK' TWICE
Note: be fast in pressing all the buttons.
FROM EKPA ONU - (+2348055790979, NIGERIA,LAGOS)
Posted on Oct 20, 2011
muhaemin89
Sikwit
SOURCE: H2 problem sharp AR 5516
is that mean, I have going down to simulation by pressing # interrupt 0 interrupt then machine wil shutdown mode than press 14 then press start.
is that true? because I mess up with my copier cannot print because code H2.
Posted on Sep 30, 2012
abidalimowla
SOURCE: AR 5516 SHARP COPIER IS SHOWING F2 FAULT CODE
F2 fault code
Posted on Apr 07, 2013
Hi can anyone help correct error code E7 10 on asharp AR 5516S copier
It's one of those dealler faults..
"Turn off the power switch, wait about 10 seconds, and then turn on
the switch again. If this does not clear the message, write down
the code (Main code and sub code exists.) that appears and then
unplug the power cord and contact your authorised service
representative. Tell your authorised service representative what
code appeared and the circumstances under which it appeared."
from the following link..
https://www.manualslib.com/manual/601912/Sharp-Ar-5516.html?page=74#manual
Feb 26, 2017 | Office Equipment & Supplies
HOW TO FIX ERROR CODE 444 BLINKING FOR SHARP AR-5516?
http://www.sharpmea.com/cps/rde/xbcr/documents/documents/om/34_ppc/AR5516-D-5520-D_OM_GB.pdf
May 20, 2014 | Sharp AR-5320 Black and White Copier
Cartage chip not accepted
My sharp xerox AR 5516 is not working and it appears F and 2 signal
Jan 10, 2013 | Sharp AR-5316 Advanced Digital Imager...
Sharp ar 5516 maintenance reset
sharp ar 5516 showing ( - - - ) what's the solution
Sep 02, 2012 | Sharp AR-5316 Advanced Digital Imager...
The printer Ar-5516 is showing H4 error
this error means:
heat roller abnormally low temperature.
for check:
1- check the heater lamp
2- check the thermistor
for reset:
clear key --> interrupt key --> "0" key --> interrupt key --> 14 --> start key
Jul 04, 2012 | Sharp AR-5316 Advanced Digital Imager...
Solutions for Sharp copier 5516 error code f 2
If you change the toner nearly it refer to toner cartridge otherwise ; press "print" key to see the sub code. and if I know the sub code I can hep you more .
Jan 12, 2011 | Sharp AR-5316 Advanced Digital Imager...
sharp ar5516 showing code f2 or h2
Jan 14, 2010 | Sharp AR-5320 Black and White Copier
74 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
