I have a prison issue amp'd mp3 player with access corrections software and security timer. After 30 days the software locks the device unless connected to the access system. Anyone know how to unlock it?
Posted by adamskyler on
Corrections
    New Friend:
The lock is a small silver slide switch located on the side of the unit labelled as "HOLD". Slide that back to the right.
Posted on Mar 10, 2016
4 Related Answers
Anonymous
  • 70 Answers
SOURCE: rca mp3 player wont connect to computer
you can easily download the software by visiting the samsung website - www.samsung.co.uk and going to their support/download page.
The most common faults with this player are
1. The touchpad fails
2. The USB part of the device fails.
These are hardware faults and cannot be rectified other than replacing 1. the touchpad and with 2. the whole unit.
Makje sure you have loaded the software correctly first of all and have restarted your computer.
If you cannot see the player in windows explorer then most likely it is the usb hardware problem.
Posted on Dec 22, 2007
Lucky
  • 271 Answers
SOURCE: my Apple iPod Video 30 GB Black MP3 Player is locked i cant unlock it
You can try to reset :
http://support.apple.com/kb/TS1382?viewlocale=en_US
http://support.apple.com/kb/HT1320?viewlocale=en_US
If you still have the problem you can try restore :
Note: Because Restore erases all of the songs and files on iPod, make sure to back up any files you've saved on the iPod disk. All of your songs, videos, podcasts, audiobooks, and games can be loaded back to your iPod provided that you have them stored in your iTunes Library.
How to restore your iPod:
For Windows:
1. Make sure you've reinstalled the latest version of iTunes.
2. Open iTunes, and then connect your iPod to your computer.
3. After a few moments, it will appear in the source list in iTunes. If the iPod's display doesn't show "Connected" or "Do not disconnect" you may need to put the iPod into disk mode to proceed.
4. Select your iPod in the source list and you will see information about it appear in the Summary tab of the main iTunes windows.
5. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download of the latest iPod Software.
The 4 possible restore options are:
Restore Option 1: Restore - Restores with same iPod Software version already on iPod.
Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available.
Restore Option 3: Use Newest Version - Restores with the latest iPod Software on your computer.
Restore Option 4: Restore and Update - Restores with the latest iPod Software on your computer.
6. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started.
When this stage is completed, iTunes will instruct you to leave iPod connected to your computer to complete restore.
7. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage.
Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
8. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
For Mac:
5. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download of the latest iPod Software. The 4 possible restore options are:
Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod, even though a newer version is available.
Restore Option 3: Use Newest Version - Restores with latest iPod Software version on your computer.
Restore Option 4: Restore and Update - Restores with latest iPod Software version on your computer.
6. A message will appear prompting you to enter an administrator's name and password.
7. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will instruct you to leave iPod connected to your computer to complete restore.
8. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage.
9. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
Or
Try to reinstall
To update and reinstall your iPod software, first download the latest version of iTunes.
http://www.apple.com/itunes/download/
Next, open the new version of iTunes and connect your iPod to your computer.
Select your iPod in the source list and click "Check for Update" under the Summary tab. iTunes will check to see if your iPod needs to be updated and perform the update for you.
Good Luck.
Live, Love, Laugh.
Posted on May 11, 2008
Jean Sintulaire
  • 758 Answers
SOURCE: Sansa c150 2 GB MP3 Player
What i would recommend you to do is to uninstall the device and reinstall it back...to uninstall it...assuming that you are running windows xp...click on start, right click on my computer and go to properties..you should have your system properties open then click under hardware then device manager...look for the sansa device..it usually located under portable device..if its not showing there i would recommend you to look for under disk drives and see if its there..right click on the device and click on uninstall...after you unintall it unplug your device from the computer....Then follow this link below to download the porting kit...http://www.microsoft.com/downloads/details.aspx?FamilyId=A2E73160-E862-4F19-BB26-C0CAFE798955&displaylang=en .Then check the mode of yuor device to make sure it sunder MTP not msc...To check the mode go under menu, settings and choose usb mode...After you check the mode open up your windows media player click on tools, options and click under privacy...clear the history and caches...after you finish you can plug the device on the back of the computer not the front then windows should recongnize it and it should work properly..if that doesnt solve the problems upgrade your windows media player to 11 even though you have done that already..and try to reconnect your device..make sure you have it connected on the back USB>>>
And if that doesnt work try to obtain the driver for your sandisk device go to http://www.sandisk.com/DriverDownload/index.asp and find the driver for your device..and then connecct the device on the back of your computer...it should work properly..if you are still having any problems..let me know..i would be more than happy to assist you..
Please rate accordingly
Thank you
Computerrep
Posted on Oct 03, 2008
noahdenza
Noah Denza
  • 35 Answers
SOURCE: How can I unlock my Mp3 player I bought in prison
It really all depends on what kind of player you have.
Posted on Oct 12, 2014
I'm released from fed prison and need my mp3 player unlock where do I send it to do so or is there a way I can do it myself
Hello, Tara -
I found some information about the Federal prison MP3 players on the Zoukis Prisoner Resources web site (one of the suppliers of services and products to Federal prisons) here:
https://www.prisonerresource.com/prison-survival-guide/things-to-do-in-prison/mp3-players/
At the end of the information on that web page, it states:
(Quote)
When you leave prison you can take your MP3 Player with you, but you will have to mail it to the Advanced Technologies Group, and pay a $15 fee, for them to remove the 14-day revalidation security feature.
(End quote)
However, the article does not provide the address for Advanced Technologies Group to which you can send your MP3 player.
I did find the Advanced Technologies Group (Keefe Group) website however. I know Keefe supplies many products and services to prisons because I know some Keefe Group employees.
This is the link to the Advanced Technologies Group / Keefe Group Contact Us web page. The phone number for Advanced Technologies Group is in Des Moines, Iowa. Call that number and ask to find out about sending your MP3 player to them, with a check or other payment information.
Best wishes.
Jun 30, 2018 | Audio Players & Recorders
I have a Amp'd Maxxpro that I received in prison. How do I remove the security software so I can be able to download music to it. Also my computer keeps stating that it is MSC device.
MSC is a set of protocols for managing communication between USB storage devices and operating systems.
In order to change the software the device would have to be wiped clean, and the original software installed back on it, you will have to contact the device manufacturer of obtaining the software if it is even passable to install it without specialized equipment.
Nov 28, 2015 | Audio Players & Recorders
I have an mp3 player that I purchased while locked up in a Federal prison, I am now at home and want to find out how to remove the security device.
Can you force it to do a "factory reset" ?
This would reset it to a state BEFORE the prison's I.T. team installed any software.
Mar 13, 2014 | Audio Players & Recorders
Amp'd maxx 4gig mp3 used with access corrections
It's a mp3 player that we got in prison. It's locked with software that won't allow us to connect it to a computer and manage files unless we pay a $25 unlocking fee. We're trying to find out if there's a way to get around the software that has locked our files(that we paid for) in our player. It's not the switch eather. That's only for locking the key pad.
Jan 24, 2014 | Audio Players & Recorders
Does any1 know how to unlock the AMP'D MP3 player the ones from Prison without having to send it in??
I have just got a used AMP'D Maxx mp3 and I would like to get the answer to unlocking the security lock also access says that upon release can spend 25.00 to unlock this device but where do we send it and who do we contact please contact me at [email protected]
Aug 26, 2012 | Audio Players & Recorders
Need security software for amp'd mp3 player
Success! If you own an AMP'D MP3 player and have been suspicious about the manufacturer's claim that attaching it to a computer will disable it....you were right to be suspicious. Leaving the device turned OFF, attach it to your computer with a USB cable, after Windows cannot find a driver, go into DEVICE MANAGER and select the device and install the ADDONICS USB STORAGE DEVICE driver located under the UNIVERSAL SERIAL BUS CONTROLLER Header. Again, leave your MP3 Player OFF. After the driver installs Windows should assign the player a drive letter and then you can simply copy the music you have to your computer. Additionally, you can write TO the player, using it as a portable mass storage device.
Feb 12, 2012 | Audio Players & Recorders
It wont pop up in the computer when i connected.
Some mp3 players, such as ipods, require a 2.0 usb connection. Most ports on the front of computers are only 1.1 and this is not even enough power to charge some mp3 players, such as an ipod.
A. Have you tried connecting the mp3 player to a different port?
B. Have you installed any software/drivers that may have come with the mp3 player on a cd? Most software is available for download if you have lost a cd or the mp3 player did not come with one. Most mp3 players do not require software to access and load music.
May 03, 2011 | Audio Players & Recorders
1,417 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
