CODE 4805
Code Entry as Follows:
Switch Radio On - Display Shows
" 0000 " with the 1st digit flashing
Rotate " Thumbwheel " For Correct Digit
Press " ¬ " On The Stalk Control To Enter
If the correct code number is now shown
Press And Hold " ¬ " Until A Beep Is Heard
Try this site for French Radio Codes:
CLARION PEUGEOT RADIO CODE United Kingdom Gumtree
First question I will ask, Did you replace the internal battery? Then what year is your Renault? Always provide the most information such as year.
Most code that worked for others is 0515
Yet I have a list of codes:
The codes I choose are for years 2001 -2004
May I suggest that you disconnect the negative side of the battery for five minutes. Then reconnect. This procedure reset the main computer which in turn might reset all codes program.
SOURCE: Radio code for Renault Megane Senic Alize 16V
Go to a Renault dealers and they will be able to help you. Main dealers have machines that can read the codes. They will charge you so you might want to ring them up and ask for a price first.
SOURCE: Renault Laguna radio code number
try instant radio codes dot co dot uk unfortunately this will cost about 15 quid hope this helps
SOURCE: were is water pump on renault senic 1998 model?
that is where the water pumnp is located.
Testimonial: "thankyou very much you were very helpful. "
SOURCE: need code to unlock radio for my Renault Megane
Give me your VIN number and i can probably help you
SOURCE: code radio renault
Hi I have a 2005 Renault Megane with a indash 6 disc cd changer but its asking for 'CD CODE' I entered the radio code but came up 'ERROR' can anyone please help.
S/NO. ALRO2M30910405
T30910405.
Many Thanks
YOUR CODE IS 4805 Code Entry as Follows: Switch Radio On - Display Shows " 0000 " with the 1st digit flashing Rotate " Thumbwheel " For Correct Digit Press " ¬ " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit Press " ¬ " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit Press " ¬ " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit If the correct code number is now shown Press And Hold " ¬ " Until A Beep Is Heard
