I have a printer scx-4623F that after reset toner, it massaged error "wait image2" What should I do to fix this error. tnx
Dear
This printer has been locked to accept third party firmware or downgrade. You can only check the firmware mentioned at back side cover panel and up date the same or higher.
If firmware fix to reset toner, may be purchased from third party and may be searched from the net.
For the error, make power OFF and ON. It will continue on previous firmware. If not then upgrade to higher version. unless MPBA to be replaced. If the printer has version bellow ,V.xx.xx.99 that are not locked and update freely with third party firmware.
If further information required pl. do comment.
Thanks.
Testimonial: "Hi, thank you for attention,samsung agency visit my printer and said its main board is damaged by bad software and must be change and cost about 110$ ! what do i do? is there any other way?"
Dear since the firmware is locked and you can not do freely however, in internet third party are doing with some money, But its advised to replace the chip (its available at very low cost, check at your local vendors or ebay) Second thing is very difficult to revive the main PBA as its need highly proffesional engineer to replace the EEPROM from the main PBA with older firmware this may help you to program freely. The last option you can do the reprogramming it higher version firmware it may revive. Best of luck. Never power OFF during programming. Thanks.
thank you for your attention, my printer has version bellow ,V.xx.xx.99 (v2.01.01.01).how can i update freely with third party firmware?
hi, thank you for your attention,samsung agency visit my printer and said its main board is damaged by bad software and must be change and cost about 110$ ! what do i do? is there any other way?
