Televison & Video Logo
m
majid Posted on Feb 01, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Whic is vertical driver ic and which is vertical processor ic in ny tv... Main ic LA76810 and vertical ic 78040... whic is processor and which is driver ic
Level 3:
Top Expert:
  • Televison & ... Master 76,851 Answers
  • Posted on Feb 01, 2015
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15005928
Points
237762
LA 76810 is the processor-chroma- oscillator jungle & 78040 is the vertical IC. Refer its schematic for more details. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Where is horizontal scan out put section?
Hi Majid
Just contact any service technician to repair your TV. It will be best for you.
Gopakumar Gopalan Google
2answers
Why come white vertical line on my t.v screen in center?
You said "I checked vertical output line from main ic pin 23 found correct"
But the problem is "Horizontal Output Line" Try that.
I have a 47 inch lg LED model 47LE5400-UC. The TV turn on, but just shows vertical lines. Does anyone know what may cause this or how I can fix this??? THANKS!
Hi, the main board of your TV is dead This can be cause by open fuses surface mounted you have to take out the mainboard and check for any open fuses specially from the main processor IC replace if you found any.you can also order a replace board at shoppjimmy.com just follow this link
search for brand and model good luck
JVC AV-27820 turn on the a white line accross middle
Hello
Total failure of vertical sweep occured whic your JVC TV. There are mainly two resons for this fault.Loose soldering terminals of the vertical output IC is the first one. The second one is of failure of the vertical output IC itself. You have to locate this vertical IC. It can be located at the main board. Vertical IC will be screwed on to a metal heatsink to radiate heat from it while it works. You can identify it very easly, if you have knoledge in electronic circuts abd printed circuit boards.
Resolder all the solder terminals of this IC first, by applying a little more solder; without making any solder bridge short in between the close adjecent solder terminals, and see whether it helps you. If not replace it with same type and number. OK.
1helpful
Horizontal line
hi,
ur tv has problem with vertical scanning section. may be dry soldering or vertical output ic faulty.
u can easily find out the vertical section on ur tv. for that u have to open ur tv. u can see a coil is fitted on the picture tube neck. there are four lines coming from the neck, of which two will go to horizontal scanning section and the remaining two will go to vertical section. follow the two thin wire normally in color green and yellow. it will go to a socket in the main board. trace the track from that socket in the main board . it will lead u to the vertical scanning section. check for any dry soldering in that section. mainly the soldering of vertical ic. if see or not re-solder the leads of the vertical ic . then check is the tv is ok or not. if complaint remains replace the vertical scanning out pout ic. it will be fitted on a aluminum heat sink in the vertical section. if u need more assistance feel free to contact through fixya.
regards
Ajin
2helpful
4answers
My LG TV Model 21FD2RG-AX have problem vertical failure its IC TDA 9340PS/N3/A/1923 vertical out put section ok
replace the vertical ic or check waveform of input signal to the vertical ic from processor, if these all are OK, check the deflection yoke continuity and replace if there have problem
Philips tv 20pt1782 want service manual
hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me..
1helpful
2answers
The TV will not power on and the red light blinks 6 times.
This is a basic blinking error code table:--
Error Code Table
0 = No error
1 = X-ray protection, E/W protection, and/or Vertical protection active
2 = High beam current protection active
3 = Reserved
4 = +5V protection active
5 = Signal Processor (IC 7150) register corrupted
6 = Signal Processor (IC 7150) error
7 = Total failure
8 = Internal RAM error (Microprocessor IC 7000)
10 = NV memory (IC7088) addressing error
11 = NV memory (IC7088) size error
12 = Histogram (YUV) (IC 7770) error
14 = Sound processor I²C error (TDA9855)
16 = Main Tuner I²C error (IC 1125)
17 = PIP Processor I²C error (IC 7350)
18 = PIP Tuner I²C error (IC 1127)
But in most cases the power cord is "defective" as it's a common issue.try with new cable 1st or else follow the chart and replace the part as per coding chart on main board.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
3helpful
2answers
LG vertical failiure vertical line at the bottom of the crt
replace the vertical driver ic and the proccesor ic
1helpful
2answers
Tv cuts off 10 seconds after switch on and destroying vertical output ic
If the main IC is not putting out a vertical drive signal then the vertical output will not do anything and therefore will not be damaged. What exactly do you mean by the set "literally eats deflection IC's"? What is the number on the vertical output IC? I will bet that your pump-up cap or pump-up diode is defective.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
