Question about Amazon Kindle Fire HD
My kindle will not charge?
I have tried plugging in the charger put it will not charge. I even tried using an alternate charger and the kindle will not charge.
Posted by Allison Mahnesmith on
Whitney Cotton
    New Friend:
    Problem Solver:
  • 9 Answers
My kindle fire HD did this, it was actually charged I just had to hold the power button until it finally booted up, almost 30 seconds. I found out this is a hard boot and have had to do it only a couple times in the past 2 years seems like its only when I have totally drained the battery.
Posted on Feb 24, 2015
ka9ior
    Habit-Forming:
    New Friend:
  • 54 Answers
The Kindle Fire HD, if completely discharged, may take several hours to begin to accept a charge again. Simply leave it plugged in long enough and the on-board system will sort it out.
Posted on Feb 03, 2015
4 Related Answers
Tim Digibrain
  • 846 Answers
SOURCE: My kindle will not charge. I plug it in and there
If you've explored all options with software settings and If you're outof warranty, you can try to open the kindle and replace the battery.There is a Kindle Repair Guide that shows you how to take it apat. There are services that can do it for you. Kindle Repair.
Posted on Jan 17, 2010
judorebecca
Rebecca
  • 17 Answers
SOURCE: how long should I leave my kindle plugged into charger
From a guess,about an hour.But keep checking on it.
Posted on Apr 22, 2012
Gil Shultz
  • 3388 Answers
SOURCE: My kindle does charge up but its all according how yoy hook up charger to the port.Some how the charger needs to be in a certain position why after awhile i cant just put in the port to charge correct
I see a trend here, get another charger and be gentel with the cables they are fragle.
Posted on Dec 11, 2014
arsh0666
noor alam
SOURCE: my kindle fire hd would not charge i got a new charger but that didnt help
you should try it from any another charger but if it still doesn't work then you have to take your kindle to service centre because its charging socket is broken
Posted on Dec 29, 2014
After being on charge all day, my kindle hd fire will not turn on.
Try another charger, or the battery may have to be renewed
Feb 23, 2015 | Amazon Kindle Fire HD 7in, 32GB
My Kindle will not charge
Here's a possibility, I just plugged in my Kindle Paperwhite using the Kindle charger and USB cable. It wouldn't charge.
I kept it plugged in all afternoon and it accepted no charge although it showed the little lightning bolt on the icon suggesting it was charging.
I unplugged the charger (it has two prongs) and reversed it so
the logo was on top and, Lo and Behold it charged. It could be the plug is not omniidirectional (i.e. it is polarized)
Feb 14, 2015 | Amazon Kindle Paperwhite
Kindle fire will not charge-got a new charger and it still will not charge- does it need anew battery and how do I do that?
The Kindle touch and the Kindle FIre are great devices for your reading needs. However, there are times when it becomes unresponsive and freezes on you. Amazon says it is because the battery isn't charged properly or does not have enough power on it. It is advisable to charge your battery first before trying to reset the Kindle touch/Fire. If theKindle still has issues, then try the steps below on how to reset your Kindle touch/fire. Please note that you may lose your data during the reset process, make sure you have made a backup of your files before proceding.
  • Hard and soft reset
    Make sure the Kindle is turned ON.
  • Press the Power button for 20-30 seconds until it turns OFF.
  • Wait for it to reboot, if it doesn't press the power button to turn it ON.
  • Your kindle should be back to a responsive state.
  • this might help you.
Dec 22, 2014 | Amazon Kindle Fire HD
KINDLE WON'T CHARGE
Are you sure your charger is working? Try charging another device with it, or try using a different charger. If you're sure the charger is OK (and plugged in!), try leaving the charger plugged in to your Kindle for a good long while, like 12 hours. If it still doesn't charge, or if the charge wears down after a short time, you might well have a bad battery. Unfortunately, later-model Kindles don't have user-replaceable batteries, and having it done professionally is not cheap. If it's still under warranty, make sure to have it fixed before the warranty expires.
Sep 25, 2014 | Amazon Kindle Fire HD
Why wont my kindle hd charge?
It could be the charger itself. Try taking the USB cable out of the charger and plug it into your computer, then plug in the Kindle. Your computer's USB port should be able to charge it. If it still doesn't charge, you might have a bigger issue with the tablet itself.
Jul 23, 2014 | Amazon Kindle Fire HD
My kindle is not charging
Is the device new or still under warranty? Is return to the store (RMA--"Return Merchandise Authorization"--through an online vendor) still possible? Extended warranty?
Is the charger (and outlet) OK? If you may attempt to use USB current from your PC/Laptop/etc., is that port workable and powered? Have you attempted an alternate method of charging? Is syncing then possible?
Chargers are not invulnerable--rarely, they sometimes overheat and die. After all, they're fabricated PRC items too--thus, even they may prove defective. (They're far less complex than a Kindle or phone, though--defective chargers thus prove quite rare.)
Chargers can't last indefinitely or through overly heavy use, either. (Chargers do tend to last longer than devices--failure proves quite rare!) Is the charger unusually hot after plug-in? (Such failure could prove a great danger to electronic devices. Very rarely, even fire or sparking is possible.) Is charger connection at the wall OK? (Is the outlet overloaded?)
Is it a "block" charger?: These may be replaced easily. Just get the connector and the Volts correct--with sufficient amperage (current). You don't need even to obtain the same brand and model as OEM--that which came originally with your charger. Online, amazon, Radio Shack, etc. may prove very helpful for such purposes.
Does the connector have sufficiently good contact through your Kindle's circuitry to its batteries? (Is the connection overly loose? Often, this occurs over time.)
Are you certain that the charging cable is OK? Does the connector in the Kindle need "doctoring" with a small tool, somehow? If the batteries are dead, it's likely possible to replace them.
It's possible that the device simply is dead (shorted-out)--power surge or fluctuation certainly are possible and likely culprits.
An extremely remote possibility is that the CPU or other key chipset is dead--even those prove useful for limited numbers of cycles. (Failure then implies quite extreme usage! Probably not!) It's not immortal!
Jun 28, 2014 | Amazon Kindle Wireless Reading Device
Kindle wont charge
Not all computer USB ports put out enough current to charge batteries. Try another port on the computer, if there is one. If you're going through a USB hub, remove it and connect the Kindle directly to the computer. If you have access to an AC-USB charger (one that plugs into a wall outlet instead of a computer), try using that.
Dec 24, 2013 | Amazon Kindle Fire HD
My kindle won t turn on
Her is a possible solution:
1. Plug into the original charger, hold the power down for a full 30 seconds, release. Let charge in this state for 12 hours.
2. Lease the device plugged into the charger, while you have the device plugged into power, press the power button for a full 40 seconds, release. Wait for 5 seconds and then press and release the power button. Did the device wake up? No, continue to step 3.
3. Plug the device into another charger, if you do not have an charger from another phone go to Staples or Radio Shack pick up a new Kindle or Universal charger, make sure you can return the charger.
4. Plug the Kindle into the new or alternate charger. Hold down the power button for 30 seconds release. Let charge for 12 full hours.
5. Unplug the Kindle from the charger.
6. Press the power button for 40 seconds - time it. Release the power button, wait for 5 seconds, then press and release the power button. The Kindle should wake up. If not, proceed to step 7.
7. If you can not wake up the Kindle from a 'hard reset' the Contact Amazon directly for a replacement.
May 25, 2013 | Amazon Kindle Fire HD
Will not power on
If you are not able to power the Kindle up, try the following:
1. Plug the Kindle into an alternate charger, if you do not own a second charger go down to Staples or Radio Shack and buy one
2. Plug in the Kindle to the new charger for 12 hours. If the Kindle attempts to power up hold the power button down until the Kindle powers down
3. When the Kindle is done charging, press and hold the power button for 30 seconds, release, waiting 2 seconds, then press and release the power button normally.
4. The Kindle should be powering up
5. If the Kindle is not powering up, contact Amazon for a replacement.
May 18, 2013 | Amazon Kindle Fire HD
Kindle will not turn on
The Kindle Fire will not turn on, correct? Let's try a hard reset.
Step 1: Unplug the device from the charger
Step 2: Press and hold the power button for 30 seconds
Step 3: Release the power button, then press and release the power button normally, the Kindle should wake up
Step 4: If the Kindle does not wake up, find an alternate charger or go down to Radio Shack or Staples and get a new charger
Step 5: Plug in the new Charger to the Kindle for 12 hours when done leave the Kindle plugged into the charger
Step 6: While the Kindle is plugged into the charger, press and hold the power button for 30 seconds. Let the Kindle charge for another hour.
Step 7: Pickup the Kindle, press and release the power button normally, the Kindle should now wake up.
Step 8: If the Kindle does not respond, contact Amazon for a replacememnt
Apr 21, 2013 | Amazon Kindle Fire HD
Amazon Kindle Fire HD Logo
268 people viewed this question
Top Amazon Tablets & eReaders Experts
Ron Rak
Ron Rak
Marvin
Marvin
Jean Thiebaux
Are you an Amazon Tablet and eReader Expert? Answer questions, earn points and help others
