Question about Rival VS230 Seal A Meal Vacuum Food Sealer
Just bought a Seal-a-Meal - how long does it take to heat up? it's been 10 minutes already, I don't feel any heat. no lights coming on, but when I pushed on the lid, the vacuum started
Just bought a Seal-a-Meal - how long does it take to heat up? it's been 10 minutes already, I don't feel any heat. no lights coming on, but when I pushed on the lid, the vacuum started, so I know it's "on"
Posted by hmkopp on
4 Related Answers
Anonymous
SOURCE: Just bought the seal a
I thought I had the same problem. Kept reading the instruction manual to try to figure out what I was doing wrong or thought a fuse was blown or something (there wasn't even a light to show that it was getting power). It did end up working though when I pressed on the ribs on the lid with some force and held it for a second or two. It didn't work when I pressed down on the lid on the sides - only when I pressed directly on the ribs. It really surprised me when it lit up, but there you have it.
Posted on Dec 12, 2010
GetMeOttaHere
  • 2926 Answers
SOURCE: Hi I have a RIVAL
Bag will not seal
• Check that there aren't any gaps, folds, wrinkles or holes in pre-sealed edges.
• Moisture of foods with high liquid content will prevent the bag from
sealing properly. Cut bag open and wipe top inside of bag and reseal.
• Make sure you've placed the bag in the proper place. When making a
bag from a roll, make sure end of cut piece is on Sealing Strip, NOT over
Lower Sealing Gasket or in Drip Tray.
• Make sure you give the appliance time to cool down. Wait at least 20
seconds between seals.
If all the above have been verified and the machine will still not pull a vacuum, you will need to replace the upper and lower gaskets.
Posted on Dec 22, 2010
pdarrach
pdarrach
SOURCE: When I go to SEAL, it burns a small hole clear thru the bag. One little metal peice on the sealing strip has burned right thru the white heating strip, therefore, it isn't sealing completely.
You need new tape to replace the one presently covering the heat element. You can get a roll of it for just US$7.99. Look at the FixYa question "where [or how maybe] can I get a new tape." I think that you have to be sure that the heat element is flat. I bought a used unit with that problem and the element had somehow gotten bent. Ordered the tape this morning and the cost is worth the hopeful fix.
Posted on Oct 02, 2012
pdarrach
pdarrach
SOURCE: Seal-a-Meal seal has blister on it
I think that you have the same problem that I have. The protective tape over the heating element [a strip in my case] has a hole in it and allows the element to come in direct contact with the bag. Also, the heating strip had a kink in it was was no longer flat. I carefully cleaned the heating strip and flattened it out as best I can. I have ordered some tape from : http://www.ebay.com/itm/170848027703?item=170848027703&viewitem=&sspagename=ADME:X:AAQ:MOTORS:1123&vxp=mtr to replace the defective one. A simple job.
Posted on Oct 03, 2012
Where can i get a new heat tape for my seal a meal
Crazy,, I've only used it three times and the heat seal already went out,,, will never buy this product again
Apr 29, 2014 | Rival VS230 Seal A Meal Vacuum Food Sealer
How to use Seal-A-Meal containers
Try Googling (rival)(VS240)(manual) without parens.
May 02, 2017 | Kitchen Appliances - Others
Jul 30, 2012 | Rival VS230 Seal A Meal Vacuum Food Sealer
Jul 17, 2012 | Rival VS230 Seal A Meal Vacuum Food Sealer
Heat sealer does not heat
Sorry to read about your problem, I hope this helps you out.
after you try to seal, open the unit..feel the white heat tape..check to feel if hot, if not..you have a defective unit....
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 25, 2010 | Rival VS230 Seal A Meal Vacuum Food Sealer
Need to find a heat strip for seal a meal vz110
Model 750 seal a meal will not seal bags
Norm
Mar 09, 2010 | Food Processors
My Seal-a-meal won't heat up to seal the bag. The motor works and the ''hands free'' light comes on, but the heating strip is cold to the touch.
just bought mine - how long does it take to heat up? it's been 10 minutes already, I don't feel any heat. no lights coming on, but when I pushed on the lid, the vacuum started, so I know it's "on"
Jan 08, 2010 | Kitchen Appliances - Others
Rival seal a meal
where can i get an instrucion manual? i bought one from e-bay, but the instructions were gone
Aug 09, 2008 | Computers & Internet
Rival VS230 Seal A Meal Vacuum Food Sealer Logo
219 people viewed this question
Top Rival Kitchen Appliances - Others Experts
Michael Thomas
Michael Thomas
Paul Carew
Colin Stickland
Colin Stickland
Are you a Rival Kitchen Appliances - Other Expert? Answer questions, earn points and help others
