LID WILL NOT LOCK TO CONTINUE THE CYCLES,,WHEN I PUSHED START BUTTON FOR 3 SECONDS TO STOP THE PROCESS, IT WILL DRAIN WATER BUT WILL NOT STOP THE DRAINING. HOW DO I FIX THE LOCK SO THAT THIS INEXPENSIVE WASHING MACHING WILL GO THROUGH THE CYCLES?
SOURCE: Maytag Atlantis Washing Machine does not ever drain or spin unless lift lid
your machine needs a new lid switch assembly!
SOURCE: maytag top loader washing machine
i believe i can help you,,but washers dont agitate in the spin cycle,,i believe you ment it wont wring or spin in the spin cycle..your lid switch is defective,,replace,,if need be i can talk you though,,onthejob
SOURCE: lid lock stays on and constant beep on excellence washing machine
i have the problem when i turn power on 2 green wash cycle lights plus the red lid lock stay on with constant beeping every second then when i push the start button the 2 green lights go out and the red lid lock light stays on but no beeps please help
SOURCE: Maytag Washer Lid lock light
Its normal for the machine to cycle the lock before starting its cycle. I'm assuming your machine is a bravos style.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
