Question about Nextar X3-02 GPS Receiver
GPS stuck up
My wife tried to clean the GPS and some liquid went inside the GPS. So when I am turn the GPS on it shows the main menu - but the touch screen does not work. Can it be repaired ?
Posted by akhilesh3252 on
Radio Code Pro
  • 2,200 Answers
Since the operating system and navigation software are preloaded into the internal flash memory of the GPS, the freezing may either be software or hardware failure. First, press the "Reset" button or push the stylus into the "Reset" hole, to see if the navigation software can load successfully. If the program still does not load, then the software may be corrupted. Also, if the internal memory fails to read or write and the software cannot load properly, it may be caused by hardware failure. In this case you must return the unit for exchange or repair to the retail location from which you purchased it, or contact Nextar for further assistance.
For technical support for your Nextar GPS see http://www.nextar.com/frontend/support.asp or you can phone them on 888-849-0846
Posted on Jul 07, 2009
  • Radio Code Pro
    Radio Code Pro Jul 07, 2009
    Please remember to rate my answer. Many Thanks.
nathan
  • 634 Answers
These units are factory service only, often cost is close to replacement cost, to keep unit clean and safe i wrap in hankerchief and put in ziplock then in glove bow and drawer at home, they are fragile and water damage prone
Keeps coming up with main menu
Fisrt thing to check is the monitor screen button.
if you clean your monitor there is chance that cleaning solution got inside the button and then even if you dont push on it, it does get a signal from the liquid trapped inside. you can try drying the solution with a hair dryer, but if the liquid leave a dry conductor inside the button this will be still there. the other option is to tear appart the monitor and unplug the button or manually try to clean the contact inside.
if you did not cleaned it, the menu button might simply be stuck in.
trying to release it can fix this.
Jan 03, 2014 | Hanns.G Corporation Computers & Internet
My GPS only shows a "non" English language. How do I fix this?
Hi
You did not mention which gps systems do you have. Anyway giving you details of tom-tom gps language change instructions.
Change the language settings on your TomTom GPS device. If your TomTom GPS receiver is set to the wrong language, change the current language to the language of your choice. Perform a reset on the device as described in Step 1. When your GPS unit turns back on, tap the button in the lower right corner of the screen to continue. Tap the next screen to access the GPS receiver's main menu. Tap on the wrench icon to access the "Change Preferences" setting screen. Scroll through the "Change Preferences" screens until you see the "Change Language" icon, identified by three flags. Tap the "Change Language" icon and choose your desired language from the list. Depending on which language you chose, you may be asked to choose a new voice for turn-by-turn navigation.
For Garmin device:-
Try this below
Touch the Wrench icon which is located on the screen with the Magnifying Glass and Map icon
Touch the down arrow
Touch the Lips/Mouth icon
Touch the top right blue box
Touch the up arrow until you see American English
Touch American English
Touch OK
This should now be in English.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Sep 07, 2011 | GPS
Turning my GPS into english talking how do i do that
To change the voice language
  1. Touch the Tool icon
  2. Touch Settings
  3. Touch Language
  4. Touch Voice
  5. Touch the Voice Language you would like to use
  6. Touch 'Ok'
  7. Touch and hold the Back button to return to the main "Where To" and "View Map" menu
Aug 12, 2010 | Garmin nuvi 250W GPS Receiver
How do I change language on tom tom?
First, turn it on.
From the map screen, touch anywhere to get to the main menu.
From the main menu, touch Change Preferences.
Scroll through the Preferences screens until you reach Change Language (the icon is a bunch of national flags). Tap it, then choose your language.
Dec 23, 2009 | Tomtom Go 630 GPS Receiver
Liquid in the unit
You need to open the unit and clean after try again if still not working try to change touchscreeen .
You can order one from here. www.satnavservice.com
Sep 02, 2009 | Garmin nuvi 200W GPS Receiver
Touch screen controls offset by an inch
To Try To Test It,Go To Main Menu Then,Seting Then,Systum Settings Then Move Over 1 Then, Press Dionostics Then Touch Screen
Jul 11, 2009 | Magellan Maestro 4040 GPS Receiver
Troubleshooting
When the Maestro is on hold the on off switch for 15 seconds. This will reset the unit. Turn it back on and it should be ok. Worked for me so far.
Aug 26, 2008 | Magellan Maestro 4250 GPS
MY GUIDE 3000 GPS Device
Try asking someone else, have you tried updateing the firmware on the gps?
Jul 15, 2008 | GPS
My Guide 3000 GPS System
it's the same menu but the pna thinks the sd isn't in, so it hides those buttons. u should get to sd card to your computer and look at addons.txt. that contains information about the menus, and if that looks alright(
[modules]
Games = "icons/games.bmp", "", 0
Navigate = "", "\\Flash Disk\\myguide\\myguide.exe"), then u should go to windows explorer. when it boots, after u hear the noise, notice a black square appearing in the left corner, "click" and hold until u see the a menu close to that when u right click your computer's desktop(if it's windows). click new folder and keep touching the desktop for the next ten seconds, so the "main menu" won't appear. then enter the new folder and windows explorer will launch, click the address bar and erase what's there and type \ then press enter. it will go to my computer. go to flash disk (which is the internal rom) and click igo launch. that should launch the navigation software.
Jul 08, 2008 | GPS
Garmin c330 no map data available
Did you try to perform a map upgrade to 2008? Turn on the Garmin and from the main menu touch the wrench,
then press Map, then look for Map info.
This will show the the current map version installed
Jan 12, 2008 | Garmin StreetPilot C330 GPS Receiver
Nextar X3-02 GPS Receiver Logo
341 people viewed this question
Top Nextar GPS Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Nextar GPS Expert? Answer questions, earn points and help others
