Question about Electrical Supplies
My predator 4000 watt generator was running fine out of the box then it ran out of gas while my utilities were plugged in and running now that I've added gas it will not restart what's wrong
Posted by Stephanie Winkler on
Generator Guru Parts
    Master:
  • Electrical S... Master
  • 269 Answers
Hi!
It might be that the fuel had particles in it that have blocked the carb jets and/or float needle.There are always loose particles in every tank. Even new ones.
First try to clear the float needle like in this video: https://www.youtube.com/watch?v=Pti7XDEcq2k
Try starting. If it will not start check the spark plug to be sure fuel is getting through. If not, clean the carb.
If you need any further help, have a look at our help centre. If the answer is not there we will get you assigned to a generator engineer who specializes in your generator.
https://www.generatorguru.com/need-help/
Kind regards,
The Generator Guru Team
Posted on May 29, 2020
Thom Lucas
    New Friend:
Too simple to believe answer
Predator 8750 Gen had same problem ... ran great new out of the box 3 months ago .. drain after each use .. add fuel and restart about every 3 weeks so no time for gas to gel. Electric starter cranks but gen would not start . Took out spark plug and used a wire brush to clean the tip. Put it back in and fired right up.
Also, for those replacing the plug, be sure to check the gap which could cause failure to start
Posted on Mar 10, 2016
tebrown507
    Sergeant:
  • 415 Answers
Try a little starting fluid to get it started. It should run from there
Posted on Feb 02, 2015
  • Annette Engel
    Annette Engel Oct 07, 2016
    Where do you put the starter fluid? I'm a girl I need more directions
  • Tom leach
    Tom leach Apr 12, 2020
    Don’t use that , reach behind the fuel shut off and hold the choke rod all the way to the left while starting
5 Related Answers
John McKinney
  • 42 Answers
SOURCE: wiring diagram for Generac engine on standby generator
here is a wiring diagram for that engine:
Posted on Mar 13, 2009
Phil Rivera
  • 83 Answers
SOURCE: My troy-Bilt 5550 watt generator will not start
First drain the fuel bowl. Any old fuel in there will keep it from starting. Fuel stabilizer is not what it's it cracked up to be. I've worked for 6yrs at a rental yard and had no luck with any fuel stabilizer, the fuel still went bad. If after you drain the fuel bowl it still will not start, you will need to clean the carb. Remove the carb and spray carb cleaner through all the accessible passages. If this does not do it, you will need to replace the carb. For long term storage I highly recommend draining all the fuel and filling just the carb with fuel stabilizer to keep gaskets moist. Then drain the carb when you take it out of storage.
Posted on Mar 30, 2009
SOURCE: Honda ems 4000 generator starts and runs great, but no power
At the controller, you need to see if it is actually sending electricity out of the Generator/Alternator, have a look where the leads from the power making unit mates, (Think of it as a motor in reverse) onto the board. There should be an AC Voltage there, then, work back, or out from there, trace the Voltage until it stops, thats the problem... Check the Breaker isn't tripped or faulty too.
Posted on Mar 22, 2010
witserv
William Robinson
  • 144 Answers
SOURCE: troy bilt 5550 generator no start please help
fuel, fire, mechanical. Miss one and she won;t run. Are you sure the gas was good? Not some old can laying around that may have turned or become water contaminated? If it was fresh gas, then take off the air cleaner and spray a little wd-40, or ether, or brake cleaner whatever is flammable into the carb throat. Just a 1 second shot is all it should need. Try and start with that. If it starts and then dies quickly, still a fuel problem. maybe a gasket is damaged, or the jet is clogged. When you said you checked for fire, you acutally took the plug out and had it grounded while spinning the motor and saw spark? If you saw a hot spark then you have eliminated fire. Mechanical not likely if it was running well a short time before. If a valve was damaged, it would still run but not too well. My gut feeling is it is related to fuel.
Posted on May 26, 2010
Testimonial: "thanks for the great help i did try fresh fuel and drained the carb bowl but still same prob its a head scratcher i really thank you for your input."
Sheldon Dedek
  • 909 Answers
SOURCE: I have a Coleman Powermate 4000 watt generator.
Hello Pete,
Is fuel actually leaking from the bottom of the bowl, or is leaking out the air filter and running down to the bowl?
If the former, then your bowl bolt's gasket has likely deteriorated. This would allow fuel to run down the bolt itself. Note that some carburetors will have a fuel shutoff solenoid (to the engine, not to the carburetor) that holds the bowl on, rather than a bolt. There will still be a gasket though. Turn fuel off before trying to service.
If fuel is running out from inside the carburetor (through air cleaner, etc), then you have a float / needle that is stuck. This is quite common after a small engine has been in storage and fuel was left in the carburetor. The residue causes the float to stick to the bottom. Turn the fuel off, undo the bolt that holds the bowl on, and carefully remove the carburetor bowl. Use a can of carburetor and choke cleaner to spray out the "gunk" in the bowl, spray off the float, and then reassemble. If it still leaks, then your needle seat will need to be replaced as well.
Posted on Sep 15, 2010
I have a Predator 4,000 generator that wont stay running. I followed all recommended instructions before trying to start it. It ran first time for about two minutes and died.same thing every time.
sounds like a fuel flow problem.Pull the fuel line off at the carb and see if fuel flows well when you turn the gas on.If the fuel is flowing to the carb,you will have to remove the float bowl off the bottom of the carb and check for fuel flow through the needle and seat which the float controls in the carb.If fuel flows well through the needle and seat and the float words well without binding, next is to clean the main jet which may be plugged.Ethanol in the fuel these days can cause problems in these areas.ALWAYS shut off the fuel in all small engines and let the carb run dry when storing small engines for any length of time.
Feb 07, 2018 | Cars & Trucks
My predator 4000 watt generator was running fine brand new ran out of gas while things were plug in and in use now that I refilled the gas it will not start what's wrong
Are you certain you used the correct fuel ... i.e. gasoline ... and not something else? If correct fuel was added, turn ignition switch to off before trying to restart.
Jan 31, 2015 | Electrical Supplies
My generator will turn over but wont start
Our motorhome Onan 5000 Marquis generator will turn over and try to start but fails everytime we test. We have primed, gas and oil are fine and we have new spark plugs. We also changed the gas filter on the generator. Any suggestion? Thanks, Loretta
Mar 30, 2014 | Watts Onan Portable Generator - 4000 ,...
I have a micro quiet 4000 starts up but surges up and down , could it be just old gas making it run so bad
The reason can be:
  1. Bad or loose ignition (spark plug, magneto, coil cable etc);
  2. Water in the gas;
  3. Dirty fuel strainer;
  4. Not set on level surface;
Jul 10, 2010 | Watts Onan Portable Generator - 4000 ,...
Onan generator not running
recheck, reclean,and rebuild carb possible had moisture in fuel and carb --white smoke--but sounds like float and carb still gummed up
Feb 15, 2010 | Watts Onan Portable Generator - 4000 ,...
4000 watt buffalo tools generator: Engine Starts, but after a few minutes it cuts out and stops running. No appliances plugged in, drained gas(it did sit for 6 months), oil is full, Plug is good.
Idle speed jet or passage and/or high speed jet/passage is clogged. Remove the carb and inspect and clean thoroughly, then re-install. Set idle and high spped screws approx 1 turn and tune to run smooth from there.
Feb 05, 2010 | Buffalo Tools 4,000 Watt 6.5 Hp Portable...
I have a 4000 watt Coleman generator that won't
If it has been in storage with gas in it. it is gunked up. Need to remove carburetor and take to someone to clean carb.
Aug 23, 2009 | Buffalo Tools 4,000 Watt 6.5 Hp Portable...
Electrical Supplies Logo
820 people viewed this question
Top Electrical Supplies Experts
Gene Haynes
Marvin
Marvin
Are you an Electrical Supply Expert? Answer questions, earn points and help others
