Well on the back of it every thing is normal but the 1 wire that is auctly stuck onto the unit had to be ?cut?. (the black wire i think it says ''USB'') does this make it usless? or how would i go about installing it?
Does the lights blink red? If so, you
have the infamous YLOD, aka. Yellow Light of
Death. This is the number 1 cause of
pS3's dying. It is an overheating issue
linked to your CPU and GPU (the
processor chips) You will need to find a local PS3
repair shop who can repair this. Do not
try to attempt repairs seen on the internet yourself. You could make
things much worse and render the unit totally unresponsive.
The repair process takes about 3 hours.
IS THERE A DISC STUCK INSIDE?
If you have a unit that is not
backwards compatible, any non 60g or 80g then you
can retrieve your disc.
Power off the unit using the toggle
switch on the back. Hold down the 'eject'
button and turn the toggle switch back
from off to on. This will run a fan test
and eject your disc. Remember, this
will only work on the 20, 40g models. Not the
backwards compatible units with the 4
usb port holes and the memory card slots.
