Question about Ariston Technologies Ovens
What means er 07 at Ariston electric oven FD 87.1 E and how can I fix the problem?
The oven is not working anymore and displays the message er 07. Also, it seems the fan is working, as it produces a slight sound inside.
Posted by Catalin on
KATHRYN SMITH
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 92 Answers
THE E USUALY STANDS FOR ERROR THE O7 IS THE ERROR WHICH COULD BE IN THE OVEN,BROILER, OR BURNERS, OR EVEN A TIMER. LOOK UP ON LINE TYPE IN FD87.1 ELECTRIC OVEN MANUAL TO SEE IF A MANUAL IS AVAILABLE THAT YOU MAY BE ABLE TO FIND THE PROBLEM.
Posted on Feb 03, 2015
5 Related Answers
Anonymous
SOURCE: DeLonghi ESS601 electric oven
We just moved in to a place that has this oven, if you use the setting with the fan with a circle round it, seems to get hot! Don't know what the other is for though!
Hope it helps!
Pete
Posted on Jun 24, 2008
Anonymous
  • 373 Answers
SOURCE: "F1" DISPLAYED AND BEEPING
F1-->Failed Thermistor Control Replace ERC
you will have to replace the ERC or Electronic Range Control or the touch pad.
Posted on Dec 18, 2008
Anonymous
SOURCE: Display on my Jenn-Air electric wall oven is very dim
douglas9101,
I had the same problem and found the solution on-line.
Replace the C3 capacitor on the dispaly module. (100 UF, 35 volt, high temperature)
The local Jenn Air dealer wanted $211 for a new display module.
I purchased a Cap from a local electronics supply store for 79cents.
The only problem is that you need to have a soldering pencil/iron, a solder ******/wick and a small amount of solder.
Steps I had to take on my oven:
- Flip the AC breaker supplying the oven to off to be save
- remove 3 screws on top and 4 on the bottom of the display panel
- gently pull out the display panel and unplug the 2 cables to the display
- unclip the ribbon cable to the display module
- unclip the module itself by pushing on the 2 black tabs
- locate C3
- unsolder C3 and replace with new Cap- keeping the polarity strip the same as theh old Cap
- reasemble in reverse order.
It took me all of 20 minutes. It may sound difficult but is very easy if you have the tools
Good Luck
K
Posted on Jun 15, 2009
Anonymous
SOURCE: Ariston oven error code F8E0
solved by rotate the temperature knob!!!
maybe would be a problem of the potentiometer or knobe of temperature
Posted on Nov 22, 2009
Anonymous
SOURCE: kitchenaid superba electric oven kebc107kss05
Did this with me twice now on self clean. It's the thermostat on the back of the oven. Set to trip when oven gets too hot which happens with self clean. Part is about $45 - $50 and pretty simple to install. Hardest part is pulling the oven out of the wall.
Posted on Dec 01, 2009
F12 error flashing on the display
Keyword Ranking Analysis for ARISTON OVEN FAULT ...
www.webstatschecker.net/stats/keyword/ariston_oven_fault_code_f12
Keyword Ranking Analysis for ARISTON OVEN FAULT CODE F12 ... fixya.com.Ariston Technologies Ariston AWD120WH - "F12 error code" issues
Aug 18, 2015 | Ariston Technologies Ovens
Can someone explain the symbols on my Ariston electrical oven? I lost my manual
Try this site:
http://search.aol.com/aol/search?&s_qt=sb&q=ariston+oven+user%27s+manual&tb_oid=07-01-2013&s_it=amonetizetest1-ie&tb_mrud=07-01-2013&tb_uuid=20130107163427450
Jan 03, 2013 | Ovens
Hotpoint Ariston FK 89EL.20 X/HA Electric Oven
Same error. No fix find yet. Only push on/off button 3 seconds.
Aug 11, 2012 | Hotpoint Ariston DY46 Electric Oven
Hi my Ariston oven shows in the display error 07. I have an ariston oven FZ 87.1 (IX)
problem je v nedostatku vzduchu pri ventilatori,treba viac priestoru pre ruru
problem is the lack of air when fan, need more space for tube
Jun 29, 2011 | Ariston Technologies Ariston FO98P...
Ariston FZ 970 CI IX The display is flashing Er 08. Can I repair this, cooking tonight John
Hi, does anyone know how to fix the problem when my ariston oven display appear Er08, thanks to advise asap!!! cheers
Nov 04, 2010 | Ovens
Er 07
i can't help you with this brand but in almost all oven of this type . inside behind the display board is a tech sheet. it will have all the answer's fault codes are a common way for self diag ovens and other appliances .. mm
Jul 14, 2010 | Neff B1421 Electric Single Oven
Jun 28, 2009 | Ariston Technologies Ovens
Ariston Oven power trip
Take off the back cover and check whether the terminals on the heating element are touching it. Normally caused by some earth leakage currents flowing from heating element to ground circuit.
Mar 01, 2009 | Ariston Technologies Ariston FO98P...
Ovens Logo
548 people viewed this question
Top Ariston Technologies Ovens Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
john h
Are you an Ariston Technologies Oven Expert? Answer questions, earn points and help others
