Every time a turn on my camera I get "Image Database File error. Recover?" then I hit enter and it says "Image Database File recovery failed". Saves and takes pictures fine but will not record videos do to error.
Would have been easier for me, when you had given the model number, but I give it a try. Most of the time you get these messages, when the file number is exceeding 999 or 9999. Or when the card or disk is full. Please try to recover all existing files from the memory (card and disk) and then try to format all memory devices.
SOURCE: my sony cybershot dsc-p2000 has a black image on it
It may happen when the lens is damaged. Or If Try pressing Up arrow of ur camera when u turn on it
SOURCE: My canon PowerShot SD750 digital camera screen
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help. Pay particular attention to Fix #5A.
SOURCE: Trouble viewing images
it should be photo carving issue. you can find more info from
http://www.asoftech.com/advancedcarving.html
