Question about Toshiba Computers & Internet
Toshiba satellite l305-s5933 computer stuck on the Toshiba leading innovation screen. it have the option to press F2 or F12, but it don't work
I done tried ctrl alt del, it blanks off and for a sec the blinking _ pop up and back to the power screen.
Posted by yalaminnifi on
Vishu Middha
  • 40 Answers
Try removing the hard disk and check if after removing HDD is must show "Boot Device Not Found" , if it shows the same it means your HDD is faulty or loose connect try reconnecting it , if remain same replace the HDD. This problem happen in common due to HDD failure as system keep on trying to detect the connected HDD but unable to detect it.
Posted on Jan 31, 2015
5 Related Answers
Anonymous
  • 2600 Answers
SOURCE: On start up my computer says rtc battery is low or
Your RTC battery or CMOS battery is either dead or too low to keep the correct settings, windows will not operate correctly without the proper date and time kept. This battery has to be replaced for your system to operate. Below is the service manual that will advise you of the proper procedure to replace the battery. Once the battery is replaced, reboot the laptop, go to the BIOS screen and reset the date and time, then reboot as normal. In the case of your particular laptop, the laptop has to be disassembled down to the lower case and motherboard. The included service manual has the procedure for this.
http://tim.id.au/laptops/toshiba/satellite%201400%201405.pdf
Posted on Nov 11, 2009
Testimonial: "thank you for your help. I will replace the batter but Im not sure what you mean by this sentence "In the case of your particular laptop, the laptop has to be disassembled down to the lower case and motherboard. The included service manual has the procedure for this. "
Anonymous
  • 1481 Answers
SOURCE: Bios stuck on my toshiba L305D-S5934 it not doing
u can re-set the BIOS by removing the BIOS battery, the BIOS battery(wrist watch cell) is the size of a Dime inside the laptop, so you need to open the laptop, i suggets you visit a technician to do this.
Try doing the following also.
remove the power adaptor and remove the battery from the notebook, keep pressing the power button for 3 - 4 mins. Refit the battery / power and re-start.
Posted on Dec 07, 2009
Anonymous
  • 23 Answers
SOURCE: toshiba satellite l305-s5933 have up at startup
Sounds like a corrupt bios to me. Download the latest for your particular laptop from the Tosh site and create a bootable usb with the relevant flash file. Restart and then try to access the bios again from F2
Posted on Mar 15, 2010
Anonymous
  • 8909 Answers
SOURCE: hello, the problem with
If you are getting the Toshiba Select F2 or F12 screen the mother board has finished with POST.
Toshiba laptops are very good normally but don't boot up if there is a device in the USB slot or a CD/DVD in the drive.
If it still refuses to POST, remove the AC Adapter, remove the battery and remove the hard drive.
Power the unit up without the hard drive and it should complete POST and complain that there is no hard drive. If that doesn't work remove AC adapter, ensure battery is disconnected and remove hard drive and RAM. Try again. If it still doesn't work, you have a mother board fault and it needs a service centre. www.Toshiba.com will help you out.
If it does work at one of the options, when you have closed the laptop down, replace the RAM first and test, then the Hard Drive.
Hope this fixes your problem.
Posted on Feb 05, 2011
Anonymous
SOURCE: I have a Toshiba A505-S6960
It seems that your computer is not seeing your hard drive. This could either be because of bios settings or more likely because the hard drive has failed. If the unit is under warranty, call Toshiba support and describe the issue to them. If not, places like Best Buy can determine for sure the cause of the issue.
Toshiba Support
Posted on May 16, 2011
My dell e5500 i was trying to download a game my screen went black and bootmgr is missing popup i tried holding down ctrl-alt-del and nothing happen on top of the keyborad a lock with the number 9 pop
Ctrl/Alt-Del
Ctrl and Alt are not repeat keys. While holding them down, press and release the Del key and you may get the required result.
But to get control again, you may have to hold the power button down for a few seconds till the computer actually shuts off, not just till it goes into sleep mode. Then a restart may give you some choices to proceed.
Apr 24, 2018 | Dell Computers & Internet
How to un freeze your laptop
You could check out the videos
Jan 30, 2015 | Toshiba Computers & Internet
What is the f2,f8, r f12 want work? only the Ctrl+ Alt+ del that wroks
If you are using windows 8, any variant, there is no f8...cheers
Jan 30, 2015 | Toshiba Satellite Computers & Internet
F2 usually takes you to the BIOS setup screen, you need to hit the keys as soon as you power up.
F12 selects on a Dell instant boot menu to select booting from CD-ROM, USB, etc rather than the BIOS options.
F8 goes to safe mode start up for windows, this must be done before the windows logo comes up (ie when it is a black screen).
Control - Alt -Delete Keys together can be used any time, after windows boots as it tells it to re-boot the computer, back to start up.
Jan 30, 2015 | Computers & Internet
Black Screen when playing 3D games on ATI Radeon 9550 X1050 Serie
the game resolution is not supported by your monitor....this is the reason your screen goes blank....
by the next time if the screen goes blank, press alt+ctrl+del together and check are you able to see the task manager....
if you can see the task manager, then close the game from that window by selecting end task....
if you cant see the task manager, then press ctrl+alt+del together 2 times and check....
if nothing works, then try by checking with any HD monitors if available with you or with your friends...
May 09, 2010 | ATI RADEON 9550 Graphic Card
My gateway is locked how do i unlock it
Assuming you mean WinXP os. Log in at the administrator's account (usually the password is blank). If you can't see this account hit ctrl+alt+del twice and at the screen type administrator and for password use none. Go start>settings>control panel>administrator tools>users, select your user account and with right click choose properties and change your password as you wish.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Mar 08, 2010 | Computers & Internet
How to soft boot a dell 4600
I used the reset button on my last one whenever ctrl/alt/del failed to soft boot
my computer.
Here is what Dell Chat tells me to do if ctrl/alt/del doesn't work:
Turn off the system from the power button. Remove the plug to the
power supply from the back off the system tower.Then hold the power
button on the tower down for 10 secs ( with the power cord removed).
Reconnect the power cord and then restart the system.This time do a
normal shutdown.
Regards,
Pp
Dec 02, 2009 | Dell Dimension 4600 PC Desktop
Floppy drive
You're talking about My PC and device manager and I'm talking about Bios.
The BIOS (stands for Basic Input/Output System) is system software inside your computer that helps the computer start up, even before Windows does. It also contains key settings about what the computer has on board.
In newer computers, it exists on a special chip called CMOS (stands for Complementary Metal Oxide Semiconductor).
You can go into the BIOS to edit or change the technical information about key components of the computer like disk drives, keyboards, and display settings. It also keeps track of the date and time.
The BIOS can normally be accessed when you start your computer. You may see a reference to "Setup" when you turn your computer on. That’s your opportunity to get into the BIOS. It usually requires the push of a function key, such as F10, to get access to it. That "F" key varies between computers. Sometimes it’s not even one of the Function keys, but the ESC key or DEL key.
If a logo screen—like HP or Dell—is displayed during the start up process instead, then you may want to check with your computer maker for a command to turn off that screen and display the start up information, which is listed when a computer is powered on.
A partial list of BIOS access commands by brand is listed at the end of this article.
The BIOS also contains the boot-up sequence. Normally, computers are configured to boot from a hard drive.
Before you do anything to your BIOS, it’s always a good idea to record the original settings on a sheet of paper that can be kept in a safe place so you can reference it later if you need to reset it.
Here is a list of key sequences for various brand-name computers. If yours is not there, check with your manufacturer or watch for info flashed on-screen when your computer first starts, before Windows begins. It may say
"For setup hit..." That will be how to get into the BIOS on your machine.
Acer: - Ctrl+Alt+Esc
ALR PC: (F2) or Ctrl+Alt+Esc
AMI BIOS: (Del), (F1) or (F2)
AST, Advantage, Award, Tandon: - Ctrl+Alt+Esc
Award BIOS: (Del) or Ctrl+Alt+Esc
Compaq: (F10) (do this when the cursor is in the upper right corner of the screen blinking)
Dell: - F1 or Del.
Dell: - Some require pressing reset twice
Dell: - Ctrl + Alt + Enter
DTK BIOS: (Esc)
Gateway 2000: - F1
Hewlett Packard: - F1
IBM:
Older Models - In order to get into the configuration of the IBM setup screen (CMOS) screen you need to hold down both mouse buttons during boot up.
Aptiva - Press F1
IBM PS/2: Ctrl+Alt+Ins after Ctrl+Alt+Del
IBM PS/2 with reference partition: - Press Ins during boot
Some PS/2s, such as 75 and 90: - Ctrl Alt ?
Some PS/2s when pointer at top right of screen: - Ctrl + Ins
NEC: - F2
Packard Bell: - F1 or F2
Phoenix BIOS: (F1), (F2), or Ctrl+Alt+Esc
Phoenix BIOS: - Ctrl+Alt+S
Phoenix BIOS: - Ctrl+S
Phoenix BIOS: - Ctrl+Alt+Ins
Sharp Laptop 9020: - F2
Sony: (F3) while you are starting the PC, then (F2) or (F1)
Tandon computers: - Hold down the key after turning on power
Tandon: - Ctrl+Shift+Esc
Toshiba Laptops: - Toshiba Utility
Toshiba: - Press Esc during boot
Toshiba, Phoenix, late model PS/1 Value Point and 330s: - Press F1 during boot
Olivetti PC Pro: - Shift+Ctrl+Alt + Num Pad Del
Miscellaneous PC’s: - Ctrl + Esc or Ctrl and Alt and +
Zenith: - Ctrl+Alt+Ins
Let me know how it is going!
This will fix your problem.
Don't forget to rate my help! :-)
Thank you for using FIXYA!
Pablo
Oct 15, 2008 | Computers & Internet
E-Machine T1100
What kind of BIOS version do you have?? here are some commands for the diverse kind of BIOS.
AMI (American Megatrends, Inc.) BIOS: DEL
Award™ BIOS: CTRL+ALT+ESC
Award BIOS: DEL
DTK® (Datatech Enterprises Co.) BIOS:P ESC
Phoenix™ BIOS: CTRL+ALT+ESC
Phoenix BIOS: CTRL+ALT+S
Phoenix BIOS: CTRL+ALT+INS
Feb 15, 2008 | E-Machines eMachines Desktop PC
Computers & Internet Logo
Top Toshiba Computers & Internet Experts
k24674
Michael Thomas
Michael Thomas
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
