I done tried ctrl alt del, it blanks off and for a sec the blinking _ pop up and back to the power screen.
Hyjacked by.
Harsha Nuwan wants more answers to this question
try starting your own post
with PC full model name and number, unlike OPs impossible post.?
what OS are you running windows what or linux? or? we dont know ,unless you tell us.
generic answers due to no facts stated by ALL above.
seems the screen is ok. (our only true clue)
so next is test BIOS. seems yours is dead.
If a laptop take out the huge battery first. works now on AC?
yes, then battery is shorted,
no, make sure power pack AC is not the wrong pack.
if PC is older than 7 years old the RTC coin cell battery inside can be bad
that causes BIOS to go nuts or dead.
Ok BIOS works ok now. (a first things first goal always)
we next test the HDD,
that is correct, if the HDD is bad, the OS is dead and the OS recovery partitions are now dead too. so doomed lacking a good HDD and new OS install media.
we test HDD using good old , free linux, boot media. like this.
http://www.pcdied.com/linux.html#Noobs
if all this sounds hard or complex? (gee it is)
get the PC repaired in a real shop.
again NO PC stated, why hyjack zero information posts?
Try taking the battery out.
SOURCE: NTLDR is missing
You need to reinstall your xp or use the restore cds /dvds that came with the laptop to repair the windows startup problem.
Files missing / corrupt.
SOURCE: my laptop says BOOTMGR is missing what does that means?
tap f8 when boot,in menu go to last good known configuration>enter,post reply if not helps will give further instructions if needed.
SOURCE: i turn my l300 on and than stops at toshiba
I have had this problem several times with other Toshiba notebooks to the extent I almost cringe when anouther person tells me they are once again having the same problem. Hopefully, the following steps I give you will correct your problem... if not, your mobo may be damaged.
There are 2 levels of checking I want you to go through in order to try and fix this. The first is a minimally invasive procedure which wont require significant intrusion into the chassis. The latter will require a more involved dismantle of the laptop for troubleshooting . . . but first:
Rule out the obvious and maybe make it all better in a couple of easy key strokes >>>>
Please don't be offended or insulted by this first, very rudimentary check. I am sure you have already checked this,but just in case, this very simple next check could mean the difference between enduring 30 seconds of embarrasment and 300.00 for a new laptop because something got hosed when you cracked open the chassis unnecessarily trying to fix a sneaky,common issue. Try starting the computer and as it turns on, simultaneously press the “Fn” key and whichever numeric key also shows a monitor image and the text: LCD/CRT. This is a key combo switch that tells your computer to route the display output to an external monitor instead of the laptop panel. There are 3 possibilities – LCD (laptop screen) Only --- LCD and CRT (external monitor) Simultaneously – and CRT -(external monitor) Only. Try pressing the FN and numeric key combo a couple of times in succession immediately when the Toshiba Splash Screen appears – this is generated by the system BIOS and just because you see the splash screen only means that the laptop may be still set to output to an external display device only and just has not executed that instruction yet. I would also attach an external monitor to the laptop and try to boot.... if the display appears on the external, or if hitting the key combo causes the laptop LCD to come back on, then stop, grab yourself an ice cold Rolling Rock Beer (or Coke if you are not 21) and celebrate a simple easy conclusion to another laptop Maalox while pondering the exact phrases of praise and admiration you will be sending to Fix-Ya about me later from your restored lap-top. :-) If still no display.... take a deep breath and lets try the following procedures in the following post (too much text for a single post sorry)
SOURCE: On start up my computer says rtc battery is low or
Your RTC battery or CMOS battery is either dead or too low to keep the correct settings, windows will not operate correctly without the proper date and time kept. This battery has to be replaced for your system to operate. Below is the service manual that will advise you of the proper procedure to replace the battery. Once the battery is replaced, reboot the laptop, go to the BIOS screen and reset the date and time, then reboot as normal. In the case of your particular laptop, the laptop has to be disassembled down to the lower case and motherboard. The included service manual has the procedure for this.
http://tim.id.au/laptops/toshiba/satellite%201400%201405.pdf
Testimonial: "thank you for your help. I will replace the batter but Im not sure what you mean by this sentence "In the case of your particular laptop, the laptop has to be disassembled down to the lower case and motherboard. The included service manual has the procedure for this. "
SOURCE: Bios stuck on my toshiba L305D-S5934 it not doing
u can re-set the BIOS by removing the BIOS battery, the BIOS battery(wrist watch cell) is the size of a Dime inside the laptop, so you need to open the laptop, i suggets you visit a technician to do this.
Try doing the following also.
remove the power adaptor and remove the battery from the notebook, keep pressing the power button for 3 - 4 mins. Refit the battery / power and re-start.
