Question about Cam Spray Pressure Washer Foamer Attachment 32 oz Bottle
I am fixing a closet in my home. It is part of an exterior wall and creates a lot of coldness in the house. How can I insulate this wall better? My kid is freezing at night she says. <a href
Insulating a wall.
Posted by bryan flake on
Eva Rusakov
    New Friend:
    Problem Solver:
  • 7 Answers
I recently had a similar issue. My children's bedroom gets very cold because their windows aren't properly insulated. I'm planning on having someone come out to make sure the entire house is insulated. http://www.climaticinsulation.com/en/spray_foam_insulation.html
Posted on Sep 19, 2015
kevininorcro
    New Friend:
  • 3 Answers
The best I found is polyisocyanurate sprayed between studs which per square foot will be very expensive in your case. One small job I did a large closet and did not put any HVAC vents and worked great.
We used one layer of 1/2 inch Rmax foil face and 3 inches iso board from roofing supply in outside walls and attic ceiling. Fill all cracks with Great Stuff. Cover all with drywall. Owner was happy for not running any new ducting in his nicely finished basement. A joining room keeps closet temp comfortable.
Posted on Feb 08, 2015
Ken Thebeau
    New Friend:
  • 20 Answers
If you have enough room behind the stud wall install 1" rigid foam tape seams and then use the thickest possible roxsul insulation to fill the studs. Or axe the foam and install 6mil plastic on warm side of the wall after insulating tape all seams when done.
Posted on Feb 02, 2015
Below Ground Exterior Wall Leak
Call b-dry are some one like that you have a problem with hydro pressure that is ground water is being forced to come up water will take the path of lest resistance . Had the same problem got it fixed several years ago and no problems sence.
Feb 18, 2014 | Cars & Trucks
Underground Exterior Wall Water Leak
First of all, why did you post in cars and trucks? Secondly for anyone to be able to help you, they would need you to paint a better picture in their head of the problem. it sounds to me like you need a professional to come in and inspect where the water is coming from and how it can be corrected.
Apr 09, 2017 | Cars & Trucks
Un insulated walls
That insulation is a very sticky mess. The hole size that you want to drill is not going to be big enough. You are going to have to get creative with trim and you should use a dry blow in insulation. The R value of the expansion foam is not as high as a blown in substance. Also using the expansion foam will leave gaps in the open space.
Jan 06, 2014 | Dow Chemical Great Stuff 12 Oz. Big Gap...
Does gas furnace need exterior air or interior air
Follow what the the makes say in there manual
Feb 02, 2013 | Goodman Heating & Cooling
I want to frame a closet do I just need 2by4's or should I use 2by6's
Framing lumber for interior non-load bearing walls is typically 2x4 in house construction. Even load bearing interior walls often only require 2x4 framing, but could require 2x6 framing depending on the load they carry(the load is how much weight of the roof or upper floors is being supported by the wall). Sometimes 2x6 framing is used for interior walls that have plumbing drain pipes to make it easier to fit them, likewise if the interior wall has heat/air ducting in it. Another reason to use 2x6 is to allow better sound proofing or higher insulation rating. If none of the special cases I've cited apply, then 2x4 is what I would use to frame a closet.
Feb 18, 2011 | Building Materials
What would cause moisture to collect on the inside of my house windows. Im in illinois, its cold and the furnace is running. It cant be good to have this water on the windows. It drips on the wood. Does...
Hello, if you have a humidifier running along with your furnace than it is set to high and must be turned down. Usually this is what causes condensation to form on the windows due to a big temp differance and humididty between the indoor air and outside air.
Feb 09, 2011 | Heating & Cooling
Maytag stackable washer/dryer gives off a lot of moisture
you answered your own question, its not producing to much miosture, its not releasing hte moisture with in the clothihng, Id be willing to bet that you have a MAJOR clog within the venting!!!!!!
Mar 28, 2009 | Maytag Dryers
Cam Spray Pressure Washer Foamer Attachment 32 oz Bottle Logo
193 people viewed this question
Top Cam Spray Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
Are you a Cam Spray Garden Expert? Answer questions, earn points and help others
