Question about La Crosse Technology E. Howard Ambassador Radio Controlled watch
How do I reset the watch the time will not change no matter what I do
Posted by Edward C Oechsli on
croft1950
    New Friend:
  • 18 Answers
Try holding down on one of the set pins for 2 to 5 seconds, then let off. some watches wont reset unless you do that.
Posted on Jan 30, 2015
How do I set digital watch of UL1159
press MODE button 3 times on left screen DAY will flash press RESET MINUTE will flash, change minute what you want by pressing START.
press again RESET button HOUR will flash press START to change hour.
Press again RESET button DATE will flash change same way.
press again RESET button MONTH will flash change same way.
press again RESET button DAY will flash change same way.
After done press MODE to bring back normal time position.
Changing ALARM ....
press 2 times MODE button. Alarm HOUR will flash press START to set alarm hour.
Press again RESET button Alarm MINUTE will flash press START to change.
After done press MODE to bring back normal position.
SO YOUR TIME & ALARM GET SET. images?q=tbn:and9gctqfaospxemzn5ytb2yvmxsagwhcrw-zhdezmqvoulno244gvhvkgaae8w
Oct 04, 2014 | Kenneth Cole Unlisted Ana-Digi watch
My Tissot touch will no longer sync - initially when in compas mode the hands were no longer aligning in a straight line and after using the compas mode i need to resync each time. Now the watch will not...
In this watch the battery should be changed after one year, depending on how often the features are used. After changing the battery the all reset should be done. Best to take it to an authorized service, and not any non authorized place to change the battery. Get in touch with Tissot for the info about where to bring the watch.
Jan 17, 2018 | Tissot T-Touch T33759851
I have a timex exped. that looses time i changed the battery twice can you give me some suggestions on fixing this problem ?
Generally speaking if a Timex needs more than a new battery (cell) it is new watch time. Anything else is either too expensive (more than a new watch) or can't be fixed. Make sure you have the cell in correctley, if there is a reset, reset the movement. This is often a matter of shorting out a small pad to ground with metal tweezers.
Mar 10, 2011 | Timex Watches
Why would this watch loose time and have to be reset???..........repeatedly.
I had the same problem sometime ago but with a fossil. I had the battery replaced several times in the matter of a couple of months. It seemed to have happened during the very cold months. I also found that I put my watch in the same pocket I put my Iphone in too. I'm not sure if there was a relevance but after I stopped, the watch seemed to fix itself.
Jan 30, 2011 | Pulsar PXX006 Wrist Watch
HOW TO CHANGE THE TIME ON MY DIGITAL WATCH IT HAS 4 BUTTONS ON THE TOP LEFT IS "LIGHT" ON THE LEFT "MODE" ON THE TOP RIGHT "START" AND ON THE RIGHT IS "RESET" THE...
Press "mode" until the hour is flashing,
Now press "start" to change the hour. When hour is correct, press "reset" and minutes should start flashing.
Press "start" to change minutes" then press "mode" again.
Oct 29, 2010 | Watches
Configuring time, date etc for my O.T.S watch
http://www.worldofsportwatch.com/en/product-3315.html
This is a link to a website that has OTS watches on it. Click on the OTS watch you have and there is a manual selection. The instructions are a bit hazy but basically you have to press the mode button 3 times, the reset button to get to what you want to change, and then the start button as many times as needed to change it to what you want. I finally corrected my watch time and date using it. Thankfully!
Jan 01, 2010 | JCPenney Armitron Sport Watch
I have a DKNY OLED watch, but when I press the button for the time, it keeps resetting itself (both time and date) and no matter how many times I reset the time, it keeps resetting itself. How can I fix...
It sounds like your watch is not coming out of set mode. Make sure that when you are done setting the watch that the display is no longer flashing. This is usually done by holding down the mode or reset button.
If this is not the case then have the watch AC'd. As long as there is no problem with the circuit board this should fix the problem.
Sep 21, 2009 | DKNY Watches
I have a Starter Brand Watch that did not come with a manual. I can't seem to get the chime to stop chiming on the hour.
Just bought a STARTER Sport Watch Model# STW14 @Walmart
TO CHANGE TIME:
1. Press and release MODE button quickly 3X in a row(top middle no.(Seconds will flash)& change Seconds by pressing START button 2. Press & release RESET button 1X quickly(Minutes will flash) & you change Minutes by pressing START button 3.Press & release RESET button 1X quickly(Hour will flash) & you change Hour by pressing START button. 4.Press & release RESET button 1X quickly(Date will flash) & you change Date by pressing START button.5.Press & release RESET button 1X quickly(Month will flash) & you change Month by pressing START button 6. Press & release RESET button 1X quickly(Day of week will flash) & you change Day by pressing START button 7. Press & release MODE button 1X quickly to return to Normal use
TO SET ALARM: 1. Press and release MODE button quickly 2X in a row(Hour will flash)& you change Hour by pressing START button 2.Press and release RESET button quickly 1X (Minutes will flash)& you change Minute by pressing START button 3. Press & release MODE button 1X quickly to return to Normal use
TO VIEW MONTH & DAY: 1. Press & Hold START button 2.Just Release START button to return to normal use.
TO USE STOP WATCH: 1. Press and Release MODE button quickly 1X 2. To START stop watch: Press START 1X quickly 3. To STOP Stop watch: Press Reset button 1X quickly 4. To RESET Stop watch: Press & Hold START button and press RESET button quickly @ the same time, 2X in a row 5.Press & Release MODE button 1X quickly to return to Normal use
Sep 12, 2009 | Bulova Watch
My timex watch is not right because the time is 24 hour time and i want to know how to change it to normal time
Select Time reset button (right lower side) until seconds flash
Select Start button on face and cycle through until 24-HR
Select Lap/Reset
Apr 13, 2009 | Watches
La Crosse Technology E. Howard Ambassador Radio Controlled watch Logo
222 people viewed this question
Top La Crosse Watches Experts
Ekse
Thomas Perkins
Thomas Perkins
Overmod
Are you a La Crosse Watch Expert? Answer questions, earn points and help others
