Question about Saws
I have a rocwell 10" tablesaw , the motor has been disconnected by My idioyic brother , I need to reconnect motor back to table wiring , the motor has 9 wires that are all labeled 1-9, I need a diagrm
I have a rocwell 10" tablesaw , the motor has been disconnected by My idioyic brother , I need to reconnect motor back to table wiring , the motor has 9 wires that are all labeled 1-9, I need a diagrm to show me what wires go where , table wire has four wires red , black, green and white, one was obvios has a loop connector the ground , the motor model number is 87-359 ,3 hp 3450 rpms, and question 2 is can I rewire to run a residential power source bring from 3 phase to two phase , I have a 40 amp double pole breaker set up with 10 guage wire run thru garage available for this table saw?
Posted by kris manoylovich on
Mike stewart
    New Friend:
    Problem Solver:
  • 12 Answers
Go to ereplacementparts.com they have diagrams that will help you. and the diagrams are FREE...
Posted on Jan 30, 2015
5 Related Answers
john224
John Prohaska
  • 1378 Answers
SOURCE: Bought an Intermatic T104 Timer for a 120v pool
T104 series intermatic timers are 208/230/277 volt clocks, not 120. I believe you have the wrong model and need a T101 series instead.
Posted on Jun 13, 2009
Anonymous
  • 351 Answers
SOURCE: Trying to replace Intermatic with Utilitech inwall
The wires on your new switch are intended for black = power .. white = neutral . and red = lights .. with two black wires on the old switch I am assuming that there is a bundle of white wires in that wall box, the white timer needs to join that bundle ... then you need to determine which black wire is the power from the electrical panel ( voltage tester) and connect to the black timer wire .. the red timer wire connects to the other black wire in the wall..
Please Vote !!
Posted on May 13, 2010
Anonymous
  • 145 Answers
SOURCE: How to wire to attic fan?
OK, your new switch will require the use of a neutral wire. So you will have to do what is called a pigtail. You will have to twist another white wire in with your other white wires to attach your neutrals to your switch. Note: white wires are called neutral not common. Hook the wires that were originally hooked up to your LINE to your HOT (Black) on your new timer, and the what was originally LOAD up to the new timer LOAD. SO as far as wiring all that will change is your white wires that need to attach to your timer NEUTRAL.
Posted on Jul 11, 2010
Anonymous
SOURCE: GE digital timer. Instructions say to: 1)
Find the Hot wire:
Your switch has 2 wires. One of these wires is Hot, and one goes to load. Disconnect wires from switch. Turn on power. Do not stand on wet surface. Test each wire to bare copper wire. When tester lights up, that is Hot wire. The other wire goes to load.
Connect wires:
Hot wire goes to Black timer wire
Wire to load goes to Red timer wire
White wire connects to white wires that are twisted together
Bare copper wire connects to Green wire from timer
How to connect white wire to white wires that are twisted together.
a) Strip white timer wire so you have 1-1/2 " of bare wire. Stranded wire will wrap around other wires easily.
b) Remove wire nut. DO NOT UNTWIST wires.
c) Hold all whites together so bare copper lines up. Wrap stranded copper around the twisted wire.
d) Replace wire nut, or use larger wire nut. Twist real tight. Do not use tape. You can solder the connection.
e) When done, pull on white time wire to make sure it is held tight. Push whites back into box.
Posted on Sep 26, 2010
William Erickson
  • 47 Answers
SOURCE: I have tried to install the Utilitech timer but am
Sounds like this was probably a three-way switch you are replacing as there is no neutral (white) wire in the box. If so, you can splice the white wire to the green wire in other three-way switch box; then hook the green wire in the box you are placing the timer to the white wire of the Utilitech timer.
Posted on Apr 17, 2011
Do you know the specs. on motor of craftsman 10"tablesaw model 315228410
Is there a nameplate on the old motor? If so, it should state the HP, speed and direction of the original motor. If not, a 1/2 HP to 1 HP 1750 RPM motor with the same size shaft that will turn the blade the same as the original should work fine. From the online manual, it appears to have an internal start switch, so the wiring should be standard.
Jun 22, 2014 | Craftsman 10" Table Saw
I own a 10" craftsman tablesaw (model #
Wait for the motor to cool then try again..... you may use compress air to blow across the motor to speed the process.
Jan 19, 2011 | Craftsman 10" Table Saw
"..... 52" unifence When turned on, the tablesaw
Hi, have you considered that the brushes on the motor could be needing replacement? Hope this helps.
Nov 15, 2010 | Delta 10"Hybrid Tablesaw with 30"Unifence
Need motor for craftsman table saw model rm871
Go to midlandhardware.com.For about $4.00 more than just price ofthe motor,you get the complete saw 15amp.motor with a laser guide!The table saw has a 3yr. warranty,3 extension wings,and a sturdy stand.Shipping to your door $24.00,$198.58 total.
Jul 03, 2009 | Craftsman Saws
Delta Table Saw stopped running
I have a table saw that the cord from the motor plugs into the the back of the on/off switch. I yours is configured like that, unplug the motor cord from the back of the switch and plug it in to the wall and see if the motor will run. If so replace the switch.
Jun 21, 2009 | Delta 10"Hybrid Tablesaw with 30"Unifence
Craftsman 10" tablesaw - Will not start. Have checked everything. Any clue why?
Hello, It could be the reset switch if it came with one. take the cover off where the wire from the motor runs to the switch and see if everything connected if not it could be the motor itself. hope this helps
steve
May 10, 2009 | Craftsman 10" Table Saw
I have a Craftsman table saw with a burned out motor. The motor model number is RM871. Where can I find one for less that the $130.00 that Sears wants for the motor. That's the price of the saw.
SOUNDS LIKE THE PROBLEM I HAD, BUT WAS JUST A SEIZED-UP BEARING. I WENT TO LOCAL ELECTRIC MOTOR REPAIR ($15.74) PARTS AND LABOR, THEY REPLACED THE BEARING, THERE ARE 2 BEARINGS ON IT, COST IS THE SAME FOR EACH. THE BEARING IS PRESSED ON, SO REPLACEABLE. HOPE THIS HELPED
Mar 27, 2009 | Craftsman 10" Table Saw
Dual voltage motor on table saw
get a step down power supply form a ac supply store.
Dec 12, 2008 | Jet 708668PK/Model JTAS - 10XL50 - 5/1PK...
Pulled out motor and did not write down where wires go back and now eather it is on all the time or nothing or it throwes a breaker in the house only 4 wires and switch and reset please help.
You'll have two wires from the motor, a black and a white. The cord wires should also be white and black. The cord black is the hot wire and that always goes in one side of the reset and out to the switch and out of the switch to the motors black. The white is a neutral from the cord and connects to the motor white. Please remeber that a black always runs thru the switch to the motor as a means of controlling the energy required to activate the motor. Be careful!
Nov 26, 2008 | Jet 708315BTC/JBTS - 10BT - 3 10 Benchtop...
Saws Logo
263 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
