Question about Mitsubishi WD52527 52" Projection HDTV
Lamp light is red
When i turn the TV on, the [power]/timer button turns green (as usual). but instead of the TV showing something, the lamp light turns red. i dont want to buy a new lamp if i am not sure it will fix the problem.
Mitsubushi WD 52527
Posted by cuks11 on
Anonymous
    Champion:
  • 205 Answers
Pull lamp from unit and investigate it for integrity
Posted on Jul 07, 2009
Got a Samsung dnie model code spp4251x/data tv when powering up the front light comes on but no picture or anything anyone got some good info??
tv seems to turn on but no picture? - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - ... Samsung Dlp TV (HLR-5067W) it seems like the TV turns on butthere is no picture. ... the lamp is, light is visible from where the lamp is located but no picture. DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
The timer, lamp, and standby/temp. light are flashing?!
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...I Have A Sanyo TV I Can Hear But Black Screen Im 14 And Dont Know What To Do ! .... power button the power light goes from red to green, the screen flashes on then goes black ....Troubleshooting LCD Backlight Failure Samsung LNT-4066 ...
Samsung plasma tv repair blinking light no picture ...
Jan 09, 2016 | Samsung Televison & Video
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
Tv keeps shutting itself off. the power button will then begin flashing in green lighting the words"timer and lamp' and in red letters the word "standby". i can press the power button to turn the tv back...
The first thing to try is a new lamp. There should be an orange or red tag on the left side of your set that has the lamp number on it. The number will look something likr BP96-01434A. It probably won't be this exact number but will have that sort of format. Google "DLP lamp" and you'll find numerous sites that sell lamps. Shop around for the best price.
Sep 01, 2010 | Samsung 61" Slim-Depth DLP HDTV
Panasonic pt-43lc14 won't turn on
Try checking your lamp door. I have seen a few of these that you need to really wrench that screw down. Let us know.
Mar 22, 2010 | Panasonic PT-43LC14 43" Rear Projection...
I followed the instruction to install the new lamp and the power light green keep flashing when turn on then turn red. After that lamp light starting flashing every 5 second. Did you know what's the...
You have to reset the lamp timer. Turn the power back on. While pressing the VOL button on the projection display, hold down the PIP button on the remote control simultaneously for more than 5 seconds. The screen should show something that says "LAMP TIME WAS RESET TO 0. The lamp indicator should go out.
Mar 04, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Replaced bulb,still not turning on-power flashes green then red and lamp light comes on
Did you reset the lamp timer? If you replace the lamp and dont reset the lamp timer the TV will continue to display the lamp error until you do.
Sep 22, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Mitsubishi WD-62525 timer light keeps flashing after lamp replace
There is a tiny reset button to the left of the timer light. Press with a pin or something small, wait 60 seconds. Viola!
Dec 29, 2008 | Mitsubishi WD-62525 62" Rear Projection...
TV not working
Check the lamp door assembly, if the lights are alternating red then green, then this might mean that the metal pin that looks like a roofing nail is not making contact with the metal clip. Remove screws, reset panel in place and turn on, the red power button should be the only light on.
Good Luck!!!
Aug 07, 2008 | Akai PT46DL10 46" HDTV-Ready Television
Mitsubishi WD52527 52" Projection HDTV Logo
273 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
