Question about Garden
I have a Yellow Stone APW-150a pressure washer bought in 2005. The hose is cracked at the fitting that attaches to the washer. Can it be replaced or repaired?
Posted by Chip Atchison on
Michael C
    Novelist:
  • 176 Answers
Though I have never heard of Yellowstone appliances, I am pretty sure there is a way to get replacement parts from the company spare parts department or from other sources who sell these pressure washers. If not, try the Internet, or try the Speed shops where they sell these to people who pressure wash their cars/trucks. I am also sure there are other hoses not necessarily for the Yellowstone brand but fit perfectly well on them. Find out where they sell other brands and take your washer to them, ask them if they can sell you a hose with the right connectors to fit your washer. No salesperson can refuse to sell you a good bargain.
Posted on Jan 30, 2015
Mark Anderson
It's a standard 15mm m22 at the pump but the gun is 1/4 inch not so you need an adapter. I found both the 15 mm m22 hose and the adapter on eBay.
Posted on Sep 24, 2020
  • Mark Anderson Sep 24, 2020
    1/4 npt adapter to 15mm m22
Install high pressure hose. Cannot get shaft of hose fitting to go deep enough into fitting so retaining clip will engage
There are several different configurations for these fittings. If you bought a generic replacement hose, it may have a different fitting than what is on the machine. May have to replace the fitting on the machine, or buy a hose specific to your pressure washer.
Apr 09, 2014 | Greenworks 1700 PSI 1.4 GPM Electric...
Tip
Washer Overflows
This advice is for a washer that fills and will not shut off, resulting in an overflow. Or, water is leaking from the washer while filling. The symptoms can apply to either a TOP LOADER or FRONT LOADER washer. This may be able to save you from an expensive service call by making these simple visual checks.
Water Does Not Shut Off and Overflows: The water level in a washer is controlled by the Pressure Switch. The switch is usually cylindrical in shape and has an electrical connection and an air hose attached. In many cases, the small air hose comes loose from the Pressure Switch fitting and/or falls off. This air hose is required to detect the air pressure from the wash tub as tub fills. With no air pressure, the switch will not function and the result will be a wash tub that fills continuously to the point of overflowing. The same would be true, if the air hose has any cracks, splits or holes in it.
Water Leaking While Filling: The other end of this hose runs to the air dome fitting on the side of the wash tub. If the lower end of the hose comes off, the water will begin to spill onto the floor under the washer, but the tub will not fill.
What to Look For: Check for the obvious. Make sure the air hose is still attached to the pressure switch and air dome. Then, inspect the entire length of the hose, paying particular attention to areas where chaffing may occur and at the points where the hose connects to the pressure switch and air dome. Vibrations from the washer can cause some wear if the hose is rubbing against anything, and the ends of the hose can stretch over time and not seal properly.
On most top loaders the Pressure Switch is located inside the operator console behind the knob that controls the water level. This knob is commonly referred to as the “Load Level”, “Load Size” or “Water Level”. On front loader washers the pressure switch location is usually located in the back of the washer behind the wash tub, or along the interior cabinet wall adjacent to the wash tub.
How to Correct: If the hose has slipped off, cut about ½” off the end of the hose and reattach to the pressure switch and/or air dome fitting. Take a small zip tie and place it around the hose at the point where it connects to the fitting. DO NOT over tighten as this can damage the air hose fitting. Just make the zip tie snug enough to keep the air hose from sliding off. If the hose has any cracks or holes, you can attempt to seal them by using electrical tape. Replacement tubing can be purchased at any hardware store.
NOTE: This is not an all inclusive fix, as the Pressure Switch can fail in some cases and cause similar symptoms. This is merely a preliminary check for a common occurrence that I have discovered. It can give symptoms of a major problem, resulting in a call for a repairman, only to turn out to be a simple fix that any Do-It-Yourselfer should be able to check and correct themselves. I hope this information is found to be helpful and saves many of you a future service call.
on Dec 04, 2009 | Washing Machines
Tip
Washer Overflows
on Jul 09, 2008 | Kenmore 24032\24036 Top Load Washer
Clear rubber hose is off machine-what does it do? I've lost the owner's manual and cannot remember how to use the electric washer. Does that short clear rubber hose with a fine filter on one end...
The clear hose with a filter on the end is a cleaning solution pick-up tube. It attaches to the washer near where the pressure hose attaches to the machine. There is ususally a barbed hose fitting for it to slip over. If you are using the black, low pressure, soap tip the hose will allow the machine to pick up cleaning solution either from a bucket or straight from the bottle, mix it in the water and spray it out on whatever you are cleaning. It will not work if you have one of the high pressure tips on the wand. They are usually red, yellow, white or green.
Jul 06, 2011 | Karcher 1550PSI Pressure Washer
My kennmore he2t frontload washer floods or doesnt drain the water. half of the water sits there and get absorb by the clothes. How do i fix this?
On most top loaders the Pressure Switch is located inside the operator console behind the knob that controls the water level. This knob is commonly referred to as the "Load Level", "Load Size" or "Water Level". On front loader washers the pressure switch location is usually located in the back of the washer behind the wash tub, or along the interior cabinet wall adjacent to the wash tub.
How to Correct: If the hose has slipped off, cut about ½" off the end of the hose and reattach to the pressure switch and/or air dome fitting. Take a small zip tie and place it around the hose at the point where it connects to the fitting. DO NOT over tighten as this can damage the air hose fitting. Just make the zip tie snug enough to keep the air hose from sliding off. If the hose has any cracks or holes, you can attempt to seal them by using electrical tape. Replacement tubing can be purchased at any hardware store.
NOTE: This is not an all inclusive fix, as the Pressure Switch can fail in some cases and cause similar symptoms. This is merely a preliminary check for a common occurrence that I have discovered. It can give symptoms of a major problem, resulting in a call for a repairman, only to turn out to be a simple fix that any Do-It-Yourselfer should be able to check and correct themselves. I hope this information is found to be helpful.
Thanks for using FixYa!!
Nov 21, 2010 | Kenmore Front Load Washer
My Kenmore 90 series washer keeps filling with water.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 29, 2009 | Kenmore Elite 45986 Front Load Washer
Washer will not stop filling with water
Mar 09, 2009 | Kenmore Washing Machines
Overfilling
Have you checked the pressure switch to ensure the rubber air hose is still attached? It is common for the air hose to come loose, or develop a small hole or crack and give the same symptoms. This may save you from having to purchase a new switch. On your model washer, the switch will be located behind the load level selector knob behind the front panel. To access, follow these steps:
1. UNPLUG the unit. There are still dangerous voltages behind the front panel with the unit shut off.
2. Remove the small panel that is angled above the washer lid and just below the operator panel.
3. Remove the cover plate under the panel by removing the series of screws holding it in place.
4. At the bottom edge on each side of the operator panel is a small screw. Remove these screws and the panel should lift up slightly, then come off, exposing the components behind it.
Look for a clear rubber hose. It should be attached to the pressure switch on a small air fitting. If not, reattach the hose and place a small zip tie around it at the point where the hose fits over the air fitting. DO NOT over-tighten, as you can break the air fitting on the switch. Just make the zip tie snug enough to keep the air hose from coming loose again.
If the air hose is in place, inspect the entire length of hose for cracks or holes. If you find any holes, I would recommend replacing the hose instead of trying to seal it. That way you avoid the possiblity of tape or sealant leaking and causing the unexpected overflow again. You can find air hose at most hardware or automotive repair stores.
If the air hose doesn't seem to be your problem, check to make sure all the electric connections are attached and making good contact on the switch. If you check all the preliminary items and everything checks good, then you may assume a pressure switch malfunction. A replacement can be found at searspartsdirect.com under the "Control Panel" heading as item number 5 (part number 134493500). I hope you find this information helpful. Let me know if you require addtional assistance.
Aug 20, 2008 | Kenmore 98702 Stacked Washer/Dryer
Garden Logo
257 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
