SOURCE: Truck (2001 Dodge Ram 1500) runs fine. Check
I found that the code is set for:
P1740....TCC Solenoid or Overdrive Solenoid performance
which indicates that a rather inexpensive fix is in order, not a complete transmission replacement!! The TCC is the solenoid which controls the locking of the transmission converter so that you get better gas mileage with no "slippage" while at highway speeds, which is normal when the converter is unlocked as you slow down. If it is locked and the solenoid fails to release it the car will stall when you come to a stop since the fluid in the converter fails to act as a clutch and the engine is connected directly to the transmission input shaft. If it never locks then the oil in the transmission will overheat at highway speeds since ther "slippage" will always be present in the converter cauasing frictional heating of the oil.
Whenever you get a quote from a shop ALWAYS get at least two more!!! No matter what the job is, even a muffler replacement get many quotes. Go to a reliable transmission repair shop and ask for their opinion. In my humble opinion the shop that told you that you need a new transmission is just hungry for work - stay away!!!!
Bob
SOURCE: my dodge is a 1996 dodge ram 1500 with a 3.9 v6.
intermittent lean condition may be caused by leaking intake manifold gaskets. Get some carb cleaner and start the truck. Open the hood and spray carb cleaner on the intake manifold gaskets. If the engine reacts at all, you have a gasket leak. If you have questions, please let me know.
