Televison & Video Logo
Question about Alba Televison & Video
Alba AELKDVD2288 screen pixelates like its poor reception but all other tvs work in the house and even plugged it into a different jack in the house where another tv works fine. any suggestions please?
Posted by Vince Knowles on
Cannot tune in my 19 inch Alba tv to main channels ie bbc and itv
POOR AERIAL SIGNAL, CHECK THE COAX JACK IS ON PROPERLY. NO OUTER STRANDS OF WIRE SHOULD BE TOUCHING INNER COPPER CORE. OR CHANGE CABLE & GO INTO THE BACK OF A SKY BOX TO THE TV, THEN RESCAN.
Namco plug+play poor picture quality
if it has multible colors the yellow has to go to the green top plug and red and white go to the furthist away from the green plug.
Poor reception on some digital channels
If possible either move the set to a room with no reception issue to see if same there or move another set to where this one is.
Usually a set does not have a problem if only certain channels.
Swap the set(looking for loose or damaged connection where cable crimps to fitting) if you can.
Pixelation of TV channels via Settop box
Pixelation is caused by poor signal strength. Check the signal strength in the setup section. Unfortunately some boxes and TVs don't handle poor signal as well as others. It might be worthwhile trying a signal amplifier
1helpful
I'm house and pet sitting at a friends' house who have a large screen Vizio TV and DirecTV. Right now, the TV is set on HDMI, but there's a floating message on a black screen: ''No Signal!'' This...
You need to make sure that is has enough signal, if you have poor signal, you will get pixels(as oppesed to snowy picture on CRT televisions) make sure all plugs are plugged in correct, and try diff inputs from DirecTV to the Tv to ensure its not the HDMI input thats faulty. Good Luck.
Headphone Jack on Envision LCD TV
just bought a coby tf-tv2617 our cable company uses a unilersal remote ur2-cbl-cv02 where can i find the code to make them work
Plasma TV Reception
Bro the reception in that area of the house must be poor, as you've said. The walls in that area of the house must be too thick, or some part of the house is blocking the signal that the attena emits. You should consider getting an antenna that can be placed outside the house, like on the roof top. Make sure it isn't being blocked by anything, like trees with large branches or whatever.
5helpful
3answers
Alba tv plays xbox 360 games in black and white
This is an easy fix.
Within the xbox, goto system settings, and chnage the display output ot pal 50.
Problem solved!
Top Alba Televison & Video Experts
 Grubhead
Grubhead
NOEL
NOEL
Are you an Alba Televison and Video Expert? Answer questions, earn points and help others
