Question about Carrier 38CKC030 Air Conditioner
Tube running from AC unit to the house is completely encased in ice. Does this mean the unit is bad ? Or, does this mean there is a freon leak in the tubing ? And, is it cheaper to replace to unit or try to find the leak at $150 / hour ?
Posted by greg_uhl on
  • Hannah Schroeder
    Hannah Schroeder Dec 16, 2017
    It's scary that the tube between the unit and the house is completely frozen. My tube is fine, but the unit itself is frozen, even though my house is starting to get hotter. I'm not sure what's wrong, but hopefully, an HVAC repair service will be able to fix it. Maybe one could help you too. http://www.socoairconditioning.com
Anonymous
    New Friend:
We had a big old iceball on the connecting point between hose & external a/c unit this past weekend. we were getting no air - hot cold or otherwise. i changed filters and turned thermostat off, let it sit, noticed major amounts of water dripping out of interior unit. Let it sit several hours (w/lots of towels) turned fan on about 5-6 hours later which was blowing air finally, then after 30 minutes of fan running, turned on a/c - worked like a charm. Until 24 hours later when the thermostat went BLANK! now we have nothing going on, and 98 degrees forecast for tomorrow!
Posted on Jun 09, 2010
woobie dog
    President:
  • 1,273 Answers
The frosted line should be encased in neoprene insulation. This can be obtained from a hardware store and cal be applied easily by yourself. Frosting can be a function of low freon, but shows also in peak usage and high humidity. If the cooling in your home has diminished,you likely have a leak. Look for an oily spot on your equipment freon lines and coils, inside and out. This will indicate where the leak is likely located. From the data plate, determine the size (BTU tons) of your unit, and look on-line for an approximate replacement cost. I had to do the same calculation this year. Call your local installer and have them come out and give you an estimate for a repair, including the cost of the freon (you may want several estimates). If the unit is older and already has a history of breaking down you may elect to replace it outright. My rule of thumb is to replace the unit after 10 -15 years of service if the cost of fixing the unit is greater than half the cost of a new one. I lean more towards earlier replacement if there is already a history of repairs on the unit. Note: if you have a leak on the outside unit, you do not have to replace the inside unit and vise versa. However, the older the unit, the more reasonable to replace the entire system to a modern, reliable system with a warranty. Hope this was helpful.
Regards, --WoobieDog--
Posted on Jul 07, 2009
Anonymous
    Problem Solver:
  • 16 Answers
This could be several reasons Low charge.... could also be dirty Evap. Coil no air flow check the filter if its clogged change it and turn off AC leave Fan in On position for a while then turn the unit back to Cool and try again.
Anonymous
  • 534 Answers
Would suggest replacing tubing from unit outside to unit inside(condensor,evaporator in order) You need to make sure that the leak is in those two lines and not in the evaporator coil or condesor coil. This can be checked by an a/c tech for around 75.00. They will isolate the interior coil, i.e. evaporator coil, and then the condensor coil if no leaks then replace the tubing.
steve
  • 3,361 Answers
You either have a refrigerant leak or a dirty inside coil or a slow running inside blower motor.
Set the thermostat for heat and run it until all the ice is thawed. Then check the incoming air side of the coil for lint and dirt. Check the fan motor for proper speed. If you have service gauges your low side pressure should be approximately 68 psi. If lower you have a leak.
MY AC WORKS FOR FOUR HOURS PER DAY AND BARELY COOLS DOWN THE HOUSE, NOT MUCH AIR COMING UP TO THE UPSTAIRS OF THE HOUSE. AFTER 4 HOURS, THE OUTSIDE UNIT SHUTS UP AND NOT MORE COOL AIR COMES IN. BEFORE THIS...
I am not understanding exactly what is happening with your unit. You say it only runs for 4 hours a day and then say that after 4 hours the outside unit shut off. But you don't describe the condition of the outside unit! Is there ice on your outside unit after it runs for four hours or is it so hot that the housing would fry an egg? Since it works for four hours and then stops working, I would guess that ice forms on the condenser grill which tells the thermostat that your air is much colder than it actually is. Then it takes time for the ice to melt off again. Am I close? If so this condition is usually caused by your unit being low on freon making everything work harder. But it could also mean that you have a leak in the system somewhere. But it shouldn't be much of a leak or it wouldn't run for the 4 hours.
I would recommend you charge it to the correct level and then check for leaks.
Aug 03, 2011 | Carrier 38CKC060 Air Conditioner
Our Subzero 611 (fridge above, freezer below) is leaking water behind the unit. We pulled the unit out of the wall and discovered that the center panel on the back of the unit had a big rusted spot. We...
That is the suction line which carries refrigerant (freon) and indicates a sealed system problem which must be attended to by an EPA "Certified" Technician.
Jul 04, 2011 | Sub-Zero 611 / O Bottom Freezer...
I have a Goodman home A/C unit and the copper line coming into the house freezes up. The unit continues to run with no cold air. I was told it is either dirty or low on Freon. Are they correct? If it is...
Hello
If you have ice on bigger copper line and no cooling then the unit is low in freon.
As far as cleaning it,you should clean the outside condenser in the spring.Use some simple green and a hose to clean the coils,this will make it better for the heat to transfer to the outside and cut your costs of running the unit down.
No you can not do freon yourself you need to be cfc certified now,which means you can not buy freon.Best to have a service person come out.
Apr 04, 2011 | Heating & Cooling
Carrier Infinity AC indoor unit in the garage is leaking water on the floor. There is no ice on the coils, The drain is not clogged. There is no water in the coil area. I turned off power to the...
It seems as though you have an unrelated water leak....
Often the water supplies are copper tubing....
Copper tubing and concrete do not get along well...
but hey it lasts till the warranty is up....
and they can't see it from their house...
heatman101
Jan 16, 2011 | Carrier 52CQ315 Air Conditioner
The plenum that houses my coils sweated repeatedly and the coils seemed to freeze. An agent told me that my unit was leaking at the fittings to the outside unit as well as the coils . The unit he used to...
Hello JBESTER Defrost the unit completely and see if the pressures are low.If more than half the charge/freon(3+)lbs has to be added you have a leak.Make sure the air filters are new as poor air flow can cause ice also.The sniffer I use beeps all the time BUT when near a leak goes crazy!The coil can leak after 6 yrs.You will always will need a recharge untill leak is resloved.
Aug 25, 2010 | Carrier 38CKC036 Air Conditioner
Ice is forming on coil fins
Either your coil is dirty or filter is dirty. Worst case your low on freon which would make a coil freeze.But freon doesn't evaporate if your low there must be a slow leak.
May 19, 2010 | LG Heat cool Window Air Conditioner
Ice builds up on the tubes just out side the commpressor, freezer will not get cold
You have a system leak or a restriction in either case this will have to be repaired by a qualified service person.
Mar 04, 2010 | Freezers
Ice formed on a/c line from a/c unit to house
Either you have a dirty air filter causing a restriction of air flow and lets hope that is the problem. Or the worst case would be low on freon. Which means you have a leak and need to get that fixed cause you can harm your compressor if it runs out of freon. Ck filter and install a clean one then let the a-coil defrost cause it is a block of ice now could take as long a 6 hours if not 8 hours.
Feb 02, 2010 | Heating & Cooling
WE have replaced our ice maker in our Whirlpool refrigerator 4 times in the last 4 years. Our refrigerator obviously is a Whirlpool and the ice maker was ordered with the ice maker installed. WE are...
If the fill tube gets choked up with ice, (Figure S-4) it usually means that the water fill solenoid valve is leaking. The valve is not closing properly and is dribbling water. If the leakage is slow enough, water may freeze in the fill tube. Over time it will freeze the tube completely shut.
Apr 04, 2009 | Refrigerators
Goodman CKL60-1L
Four things cause icing up:
( 1 ) Is your filter clean? dirty filter blocks air flow causing iceing up. replace filter
( 2 ) Do you hear the Indoor fan running? If the fans not running the unit ices up. Check Capacitor to fan if good.
Bad fan motor... replace fan motor and cap. If both good
( 3 ) Check Air Handler evap coil if dirty and or clogged, restricts air flow causing unit to ice up. Use toilet brush to clean.
This is always a big possibility if you have pets.
( 4 ) If the above are not present then you are low on refrigerant.
Low refrigerant will cause icing up because the gas does not flash properly. This will require a service tech.
refrigerant leaks can be as simple as a loose cap on the king valve, leaking schrader core, to coil leak.
Have the service tech show you the leak. If it is in a copper line it can be fixed. If the system is over 10 years old limit the amount you want to spend. 10 years is the standard life expectantcy anymore. Good luck
May 20, 2008 | Goodman CKL60AR60 Air Conditioner
Carrier 38CKC030 Air Conditioner Logo
283 people viewed this question
Top Carrier Heating & Cooling Experts
Dennis Boxerman
jdthefixer
Marvin
Marvin
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
