Last night my Samsung plasma TV made a fairly loud popping sound while I was watching it and then the power went off. When I turned back it on, no picture but sound was o.k.
Googled the issue on line and found a video clip from ShopJimmy.com. In the video, the technician mentions that losing picture after a loud popping sound is due to the Y-main board when it goes bad. I was wondering if other boards in the TV set can cause a popping sound like that when something parts go bad.
Re: Hello,
Last night my Samsung plasma TV made a...
Yes the caps on theower supply, but you can check power supply board by smell an look for burnt parts it is common. May need more than one board if they are cheap get both.
? 13:57
https://www.youtube.com/watch?v=UKoR7pWAHzk
Nov 25, 2014 - Uploaded by Robert DIY
TV Power board replacement - 30 - 60 minutes ($20 / $110 / $250 / Replacement) This video will show you ...
Nov 23, 2011 - 7 posts - 3 authors
While watching TV, I heard a loud pop, then the tv went dead. ... Ok, so I tested the fuses and the main fuse, by the power plug, had no ...
CNETFeb 14, 2012 - A defective capacitor in some Samsung LCD, plasma and DLP TVs is causing the ... The LN-S4051D is one of the TVs Samsung admits has issues ... In a February 9 report entitled "More than 7 million Samsung TVs plagued by possiblepower defect", ..... Today I heard a loud pop and now I have no picture.
Check the power board for any domed capacitors. Replace them. If this does not fix Replace the power board. You can check the voltages from the power board. they are labeled. VS and VA voltages are the panel voltages.
The x-sus or y-sus panel wil be the fault.Check the fuses on these panels ,if one of the fuses is open then that panel must be replaced.Not verry cheap to replace.
There is not much you can do to fix your plasma. Since the plasma is less then 1 year old, still under Samsung warranty.
I would suggest to call them to fix it.
Good luck.
