Question about Renewable Energy
What type of window film available in the middle east
Solar film for windows
Posted by solargard on
What kind of batteries are used in solar street lights?
Nowadays, LED Street lighting is a fresh new alternative to traditional street lamps such as LPS, HPS, or MH Street lights. Also, it provides a multitude of advantages over a conventional incandescent light. Moreover, LED Street lights are environmentally friendly, energy efficient, and cost-effective. Solar lights can use a different kind of battery such as Lead-acid battery and SMF, lithium-ion battery or Li-ion, lithium-ion battery phosphate or LiFePO4. However, if anyone is looking for sustainable energy products at a reasonable cost, Please Visit here: http://www.citizensolar.com/
Aug 27, 2018 | Solar Electronics - Others
My solar panel is not working in my birdbath fountain. When I did a troubleshoot it said to test the unit with the fence unhooked. What is the fence?
Check the pump to see if there is a blockage stopping the impeller from moving. If you have a volt meter, measure the output of the solar cell in bright daylight to see if it is producing the correct voltage.
Jun 19, 2016 | Solar Electrical Supplies
How to put solar tint at home
Do you mean use solar tint at home on a window? If so here is how its done. Go to Home Depot or Lowes, where ever you can find large rools of film. I got mine at Home Depot, get correct size to fit window or glass door you want to cover. It comes on different shades from real dark to almost clear. Clean glass an follow instructions about which cleaners not to use. Cut film over size an lay on glass, use squeeie to press out bubbles. Its not as hard as you think but it does take practice to do correctly. I had some bubbles but not real large ones so I left it alone. Door glass came out fine windows not as good. Hope this helps.
Jan 29, 2015 | Cars & Trucks
How does window insulation film work?
Solar control film (if that's what you are asking about) helps reduce heat transfer through windows. The film absorbs the UV elemnt of the sun's energy while reflecting the infra-red elements.
Feb 05, 2014 | Insulation
What's an example of a passive form of solar energy?
Passive solar energy can be used to keep buildings warm. Some buildings have large windows on the side of the building the sun hits. The sun's ray go through the windows and penetrate the heat-absorbent floors and walls. At night, this heat is released into the building.
Jul 23, 2013 | Renewable Energy
Pacific Image PrimeFilm 1800u Film Scanner : is there a Windows 8 driver out there somewhere? Can anyone offer some help in finding it?
PrimeFilm 1800u will not work on Windows 8.
Here is the response I received from the company for the question:
Where can I get drivers for windows 8? Windows 7 drivers are not working on Windows 8.
Response:
Hello, This scanner will not be supported on windows 8, all of our USB 1.0 technology scanner will no longer be supported beyond Windows 7.
Wendy
Dec 19, 2012 | Pacific Image PrimeFilm 1800u Film Scanner...
Can`t find driver for pixma i2000 for windows 7
hi there, here is the link on the europe/middle east/africa site: http://software.canon-europe.com/products/0010093.asp
Apr 16, 2010 | Canon PIXMA iP2000 InkJet Printer
Dirty Water in water softner tank
Solar salt is full of sediment and even stones at times. Al that white scum on top is the reaction between the salt and sediments in solar salt. All that sediment gets drawn into valve during brining and causes many problems. That stuff is cra***. Use either Dura cube or Hardi cube salt and you will not have this problem again. It is available from most water treatment dealers
RJ
Dec 29, 2009 | Culligan Sediment Water Filter Heavy Duty
I had new film put on back window of my 1997 Toyota Camry and I now have a black line going up through the middle and a black line on the side, What is this? I don't feel safe driving. Altha Breininger
your puted the new film your sef or by another man?
if is the second , you must know that the film that is puted isn,t one piece all,
and the man that puted the film have joint together in the midle of your window and in the side the film(films beter, and from your prescription i think you have 3 pieces) so isnt problem, only may obstruct you to beter see from the center mirror that you have in your up right.
Mar 29, 2009 | 1997 Toyota Camry
All settings have changed to arabic mode
f8 in boot up screen and select safemode
Jan 04, 2008 | Acer Aspire 5580 Notebook
Renewable Energy Logo
1,000 people viewed this question
Top Renewable Energy Experts
Greg Scott
Greg Scott
Lukas Alexander
Level 1 Expert
Are you a Renewable Energy Expert? Answer questions, earn points and help others
