Dynex DX-L32-10A 32" LCD HDTV Logo
Question about Dynex DX-L32-10A 32" LCD HDTV
I have a Dynex 32" TV. I have lost the remote. I am using the controls on the TV, Menu, +-Volume, <> input and on/off. I am stuck in the menu and can't get out. Can you help me? Thanks
Posted by Jean Arriaga on
Charles Berry
    Welcome Back:
    Visited the website for 2 consecutive days.
Try unplugging the tv, push and hold the off/on button for 30 seconds. Replug and try.
Posted on Jan 14, 2022
5 Related Answers
Anonymous
SOURCE: Program a universal remote for the Dynex 32" 720p Flat Panel
Try using the codes listed for Orion products. Worked for me.
Posted on Feb 17, 2009
Anonymous
  • 40 Answers
SOURCE: No picture on new Dynex 42" lcd hdtv
Do you have cable or DVD player connected yet? If not, connect your cable to the back of the LCD via Coaxial cable. Next turn channel to 3 or 4 whatever channel you use for cable. Then use auto programming to find all of your cable channels. If no cable connect the DVD outputs to one of the AV 1 or Av2 inputs on the back of your LCD. Power on the DVD player and change your input to which ever AV you connected it to. You should see a blue screen and your DVD Player Icon.
Posted on May 13, 2009
Anonymous
SOURCE: cant use fios remote to power/volume
Yesterday I called Dynex at 1-800-305-2204. The rep gave me 0463 which didn't work when I called VERIZON FIOS but the Dynex rep did inform me during the call that if it didnt that Dynex is comparible with Orian, Emerson, Memorex, Sansui, Sylvania and Zenith. So any of these tv codes should work. The code of Orian which is 0490 indeed worked!!!! And when you call Verizon make sure when they help you program your remote that they do the second step if they dont tell you which is add the code 799 which will let you just push STB then Power to cut on/off the tv. My bedroom tv, I always pretty much had to use the tv remote to cut on and off but when the Verizon rep gave me that step for the original tv I was having problems with told me this step, I had her walk me through the other tv remote and add that code and its great. She said that alot of technicians just been taught the other way. Hope this info help you.
Posted on May 24, 2009
Anonymous
SOURCE: my dynex remote control for 32 inch flat screen
I just called Dynex because I had the same problem. Remove the batteries and press the power button and hold it down for 15-20 seconds, put the batteries back in and try to power on and power off, change channels, etc... if so the remote is fine. The guy told me that sometimes when you need to replace the batteries you also have to re-set the remote control.
Posted on Mar 28, 2010
Anonymous
SOURCE: Need the three digit code for using in RCN Remote
169 worked for me
Posted on Sep 21, 2010
1helpful
Remove subtitles from Dynex TV DX-19E220A12. Anyone know how to do this please? Thank you.
What is the TV source (input)? Usually the captions are only controlled by the TV if your source is Antenna/Cable (using the RG-59/RG-6 cable input). If your source is a set-top box (HDMI, component or composite video), consult the documentation for that source.
If your source is set to TV, press Menu (on the remote or the side of the TV). Use the Left/Right arrows (or the Channel buttons on the TV) to select Settings and press Enter (input button on the TV). Use the Up/Down (or the volume on the TV) arrows to select Closed Captions and press Enter. The highlighted menu item should be CC Mode. Use the Left/Right arrows to choose Off. Press Enter to save the setting. Then press Menu to change another setting or Exit to leave the on-screen menu. See page 31 of the user manual available from ManualsLib here: https://www.manualslib.com/manual/445548/Dynex-Dx-19e220a12.html . The current link to the page is https://www.manualslib.com/manual/445548/Dynex-Dx-19e220a12.html?page=35#manual .
Some set-top boxes will have a caption control button on the remote control. Others have more difficult steps. On my IPTV box, I have to press Menu, select Settings, then enter a pass code provided by my provider. Then I enter the Hardware settings and find the closed captions menu under Audio Settings. On an old Dish receiver, the caption controls depended on the system mode. Since the receiver could serve a primary and secondary TV, captions could be viewed on the primary set or both. They could only be changed at the primary TV.
I hope this helps.
Why is menu scrolling uncontrollably when turning on?
Vizio L32 32 in. LCD HDTV Scroll stuck - Questions - Fixya
www.fixya.com > ... > Vizio > Vizio L32 32 in. LCD HDTV
Question about Gateway Flat Panel Televisions. 2 Answers · Menu stuck on andscrolling. menu stuck on and scrolling The TV remote control will not operate the TV, and now the ... Menu Scrolls Uncontrollably ... To turn off the TV, I have to .
Vizio LCD 37 Inch Turns Off Randomly - Fixya
www.fixya.com/support/t354860-vizio_lcd_37_inch_turns_off_randomly
Flat Panel Televisions question. ... I have a 2006 Vizio 37 inch LCD that has started to turn itself off randomly. ..... Why is menu scrolling uncontrollably when turning on? will stop randomly on one input, but will scroll uncontrollably when any ...
Vizio E470VL 47 in. HD-Ready LCD TV Scrolling menu ...
www.fixya.com > ... > Vizio > Vizio E470VL 47 in. HD-Ready LCD TV
Question about Gateway Flat Panel Televisions ... menu stuck on and scrolling TheTV remote control will not operate the TV, and now the menu is stuck ... How to activate the menu choices? try turning tv off and ... Menu Scrolls Uncontrollably.
HOW DO I GET TO TV MODE WITH MENU BUTTON. MY REMOTE HAS BEEN LOST
From the manual of one their 32" TV's:
Press INPUT button on the TV set or remote control to display the input source menu, and use CH+/- button on the TV set or / button on remote control to select the input source, press ENTER button on the remote control or VOL+ on the TV to enter. http://www.curtisint.com/html/custservice/manuals/PRO_PLDED3257A-B_EN.PDF
unplug your TV for 30 seconds and then plug it back in. Or just follow the directions on screen on how to use the volume control buttons and that should help.
I've lost the remote control for my AOC Envision L32W761. How can I change the menu and input source options using the front panel controls? I'm able to access the menu screen but can't figure out how to...
Try navigating the screen using the volume and channel controls. If you still can't get to the left side of the screen then try press the menu button again while on the menu screen to see if it'll navigate you there.
Hope this helps :)
2helpful
Switch the tv to video without the remote
On some Dynex TVs, there are control buttons on the side of the TV (Volume controls, Channel controls, Menu, Input and Power). Just press the Input button until you get to the correct source.
http://www.dynexproducts.com/products/televisions.html#support=open&active=false&pageNumber=1&subcategoryId=31-to-40&resultsPerPage=all
will let you find your model and get a copy of the manual to check where those buttons are on your TV.
I hope this helps.
Menu keeps flashing remote control wont work, cant change channel or volume.when i hold down channel up andmess with remote sometimes it changes channel. channel down button is only one that doesnt change...
U have 2 situations:
1st U have a tv Key stucked or internal control board defective.
2nd U have a broken tv remote control.
Note: Check for stuck pressed keys on TV, if not send to repair shop, for checkup.
3answers
2helpful
3answers
Trying to program the tv with the direct tv remote
Not out of luck, Dynex.com says to use codes from other model of televisions. The way I did it (I have a DirecTV remote as well) is just did a code search till I found which one turned it off. The only thing it won't do is change which input you use, but the menu, volume and channel controls all work fine.
4helpful
2answers
How do i run a channel scan? there is nothing in the manual
Found this in the most frequently asked questions at the Dynex customer support website on page 3. the website is:(http://www.dynexproducts.com/pc-680-23-dynex-32-720p-flat-panel-lcd-hdtv-matte-black.aspx) You can also call the customer support telephone number at 1-800-305-2204. between the hours of 7am-12am CST. Give them the model number of you television and tell them you are having problems completing the autoscan of the television. I hope this information helps you with your problem. 1.How do I set up my channels or run an autochannel search? 2.Are you using a cable/satellite box, cable connected directly to the TV, or an antenna? 3.If you are using a cable or satellite box you must use the remote that came with that box to change channels. 4.Make sure you have the correct input selected to view channels via the cable or satellite box. For example, if the cable or satellite box is connected via component cables please press input and select Component 1 or Component 2 to view your channels. If you are using cable connected directly to the TV: 1.Press MENU. The on-screen menu opens. 2.Press < or > to select Channel, then press v to access the Channel menu. 3.Press ^ or v to select Air/Cable, then press < or > to select Cable. 4.Press ^ or v to select Auto Scan. Press > or ENTER. 5.Press ^ or v to select Cable System, then press < or > to select your type of cable or satellite system. You can select STD, IRC, HRC, or AUTO. If you are not sure what type of system you have, select AUTO. 1.Press ^ or v to select Start to Scan, then press > or ENTER to start scanning. Your TV memorizes all cable channels you receive. If you are using an antenna: 1.Press MENU. The on-screen menu opens. 2.Press < or > to select Channel, then press v to access the Channel menu. 3.Press ^ or v to select Air/Cable, then press < or > to select Air. 4.Press ^ or v to select Auto Scan. Press > or ENTER. 5.Press ^ or v to select Start to Scan, then press > or ENTER to start scanning. Your TV memorizes all analog and digital channels you receive.
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
