Question about Whirlpool LGR3624JQ Gas Dryer
Whirlpool Gas Dryer
Hi
I can't seem to find the pilot on my gas dryer. Any suggestions?
Posted by bpnc on
Jeff Rockwell
  • 5,911 Answers
Pilot Light? Are you sure? All the gas dryers I've ever worked on were pilot-less. There should be a glow-type igniter that heats up when the dryer is turned on. When it reaches a certain current potential a gas valve is opened and the burner ignites. How old is this dryer? Maybe this is something I've never seen before. Is the dryer working at all? If not, here's a way you can narrow down the possibilities of problems:
You need to gain access to view the inside of the dryer, first. With the dryer plugged in, push the start button. If you hear a "click" and the igniter still does not come on, you probably have a bad igniter. If you don't hear a "click", the radiant heat senor is probably bad causing the igniter not to glow. You have to listen very carefully for the clicking noise, though. It's not very distinct with some dryers. Now, the igniter can glow sometimes and still be bad. The way your dryer works; it looks for a certain current potential (roughly 2.7 to 3.2 amps depending on type of igniter) on the igniter before the gas valve opens to ignite. If the igniter is weak, the gas valve may not open. This is a safety feature that prevents gas from leaking into your home. I hope this may help you. Let me know if I can assist further.
Posted on Nov 12, 2007
My whirlpool gold dryer doesn't have any heat coming from it. Could my pilot light be out?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 19, 2011 | Whirlpool Dryers
I have a Whirlpool gas dryer, I can see through the hole that the piolet light is not lit. Model #LGR7646EQ3. It is not heating to dry clothes, can I just try & relight the pilot light?
heatman101
Aug 28, 2011 | Whirlpool Dryers
My Whirpool dryer Model LGR 563 isn't heating now. Does it have a manual or electronic pilot light? I don't see a pilot light lit through the hole.
heatman101
Apr 24, 2011 | Whirlpool LGR5636PQ Gas Dryer
Pilot light goes out about 2 minutes after starting dryer
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 25, 2010 | Whirlpool LER4634J Electric Dryer
My dryer dosent seem to fire up is there a pilot lite that needs to be lit?
its automatic pilot like a bioler could be the gas valve inside that went bad on it or just some good cleaning will do it
Jul 05, 2009 | Whirlpool LGB6300 Gas Dryer
Dryer repair
There is no pilot. It is electronic ignition via a glow bar.
Remove the front panel. The glow bar and gas valve will be on the bottom right side.
What is your problem?
May 20, 2009 | Whirlpool LGR5636L Gas Dryer
Whirlpool dryer not heating up
It does not have a pilot. It uses a glow bar ignition system. You probably have a bad glow bar if it is not heating at all part number 279311
Apr 06, 2009 | Whirlpool LGR3624JQ Gas Dryer
Whirlpool gas dryer motor wont turn over
If the drum is not turning, then the belt may have broken and could be (because of the noise I think your describing, partially wrapped around the motor pulley.
Modern gas dryers do not have standing pilot lights. They are electronic ignition.
Chances are, you solve the belt problem, you'll solve the (I guess your having) heat problem.
Please respond with more detail of the problems you are having, and advise if the belt is broken.
Jan 18, 2009 | Whirlpool GGQ8831L Gas Dryer
Whirlpool gas dryer heat goes on then off then on again
should have electronic igniter that light gas after turned on.
Jan 03, 2009 | Kenmore 73952 Gas Dryer
Whirlpool gas dryer
Did you check the coils for the gas valve with a meter for ohms resistance?
Aug 09, 2007 | Whirlpool LGR3624JQ Gas Dryer
Whirlpool LGR3624JQ Gas Dryer Logo
154 people viewed this question
Top Whirlpool Dryers Experts
Marvin
Marvin
John Tripp
John Tripp
Ned Halaweh
Ned Halaweh
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
