I moved my roland vp540 to my new office up a flight of stairs when i hot it up there cyan leaked everywhere and now not printing yellow or magenta please help.
Posted by Michael Herrera on
David Del Polito
    Habit-Forming:
    New Friend:
  • 44 Answers
Go to the manufacturers website for that answer
Posted on Jan 29, 2015
5 Related Answers
Anonymous
  • 59 Answers
SOURCE: Magenta printing as yellow
Well, first off, are the alignment, and nozzle check sheets looking good? If not, then work on that. If so, then we have a problem. Try creating a test sheet in Word. Make red, yellow blue & black text and see if anything else prints wrong. Get back to me!
Posted on Jun 19, 2007
Anonymous
  • 619 Answers
SOURCE: printer cartridge's cyan and yellow not printing
replace w/new ink and nozzle check , if test nozzle print ok , if the same happened , head cleaning , test print , all solor solid nothing gap or blank within the color , mean good , try to print variety color picture.
Posted on Jan 04, 2008
John K
  • 12 Answers
SOURCE: iP4300 only recognizes magenta OR cyan
1. Get compressed air
2. Run Printhead under HOT water, do not worry about contacts getting slightly wet.
3. Blow compressed air with straw attachment into screens where the cartridge nozzle sits on printhead. then let it sit and dry.
4. reinstall print test page
5. if this fails open paint/photoshop and print a page of the color that is not printing correctly. rinse and repeat until colors flow freely.
I have several ip4300s and I have yet to give up the ghost on a printer with a clog ujsing this method.
Posted on Jan 21, 2009
Anonymous
  • 32 Answers
SOURCE: Xerox Phaser 8560 Color not correct
the problem is not with the printer but it is with the ink that might be damaged, this is located inside the printer
Posted on Dec 01, 2009
William Charnigo
  • 615 Answers
SOURCE: Canon Pixma yellow color problem
Either the ink you are using is not going to give the color you want, or you have print heads that are blocked.
Posted on Mar 28, 2010
My c353 konoca Minolta is showing p7, p8, p21 and it print test page with black and cyan only.
Replace the black drum and developer unit along with the magenta (P-7) and yellow (P-8) image units and Transfer belt (P-21)
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Dec 07, 2017 | Minolta Office Equipment & Supplies
Cyan and magenta toner cartridge not releasing
replace yellow image unit
Nov 22, 2013 | Konica Minolta magicolor 5430 DL Laser...
My roland vp-540 will start printing and then when busy printing it will just stop, if you go into your versawork on computer it just says not connected? What could be the problem?
Just one Question?
Do you have your LAN Cable tied with your AC power Cable?
I have th same problem on two VP540 after seven years of trouble free working. A few months ago I was reorganizing my shop and I tied up both cables to avoid tangle cables with machine wheels every time I move It.
I think that the noise produced by AC Voltage Affect the VP540 ethernet port.
Aug 14, 2012 | Roland VersaCAMM VP-540i
All four colors wont print roland sp300v
you print head is dry out. Normally, it happened on Magenta and Cyan colors.
Apr 09, 2010 | Office Equipment & Supplies
Mar 11, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
Printing problems
try to clean the noozle of you catridge..... then try again...... or try to shake it
Sep 01, 2009 | HP PhotoSmart 7960 InkJet Printer
Canon PIXMA iP 3000: Suddenly, everything prints hot pink
It sounds like the cyan and yellow cartridges are empty. Try new cartridges.
Dec 09, 2008 | Office Equipment & Supplies
64 people viewed this question
Ekse
Marvin
Marvin
