Question about Whirlpool WTW6400SW Cabrio Washer
MY WASHER IS LEAKING WATER INSIDE THE TUBE WHEN IT IS NOT IN USE.
Posted by Nicole Marie on
  • callmechaz Jan 28, 2015
    Hi Nicole Marie, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Leaking in what tube? What is your question?
Mohamed Bahha
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 60 Answers
I think the same as george nava
You have a bad water inlet valve the one the hot and cold water connect to. their fairly easy and inexpensive to replace. just remove the cabinet housing and will have a couple screws, it can also be checked with a multimeter for continuity , they should be able to test it for u at any appliance store
Posted on Feb 07, 2015
Jorge Rendon
  • Whirlpool Master
  • 5,420 Answers
Posted on Jan 29, 2015
Narinder Chhina
    New Friend:
  • 153 Answers
Try to clean fill valve screen if not work change the fill valve must be stuck
1 Related Answer
Anonymous
  • 90 Answers
SOURCE: My washer is leaking water near the water tube
most likely u will need to replace part.u should remove the cabinet to get a better look at where the leak is . the cabinet comes off from the front.
Posted on Oct 27, 2009
How to fix a GE Topload Washer leaking down the inside center of the machine back pannel?
check the tube that goes from near the bottom of the tub up to the level control switch
Jul 09, 2017 | Washing Machines
The water will run into washer, but will not stay in washer, but not leaking out anywhere
sounds like your drain tube is to low and the water is just running out the drain , the drain tube should be at least a little higher as the washer
Jun 16, 2012 | Frigidaire Gallery GLWS1339EC Top Load...
Washer machine is leaking water on the left corner
Hello my name is Heath it will be my pleasure to assist you. If the machine is leaking water on initial fill or when the machine is filling with water then the fill tube is the problem order a new fill tube and replace . You will have to lift the top to find exactly whaere the water is coming from.
Jun 15, 2010 | GE WBSR3140DW Top Load Washer
Water leaking from pump
Check out the last page of this manual: http://www.karcherresidential.com/support/downloads/pdfs/handbooks/pumps/Pump_629.pdf
The hose going to the soap-intake has probably fell off and the ball and spring that should be inside the intake has fallen out.. Find them or buy new. I have the exact same problem.. :-/
Apr 27, 2010 | Honda Maxus Prosumer MX5223 Pressure...
Water not cutting off at full level and leaking-Kenmore washer 80
The water lever sensor/switch is not working and needs to be replaced. IT has a air tube that senses the water lever by pressure. It the tube is clear then the switch needs replaciing,, If they is a clog, clear it and retry before replacing it.
Feb 06, 2010 | Washing Machines
Leaks water when filling up.
If the washer is leaking only during the fill and not all the time, the problem is most likely caused by a faulty air gap device, a leaking water inlet valve, or the tube. The air gap is a small device that keeps the washwater from being siphoned into the household water supply. It is usually located mid-way or at the end of the black hose that comes from the water inlet valve. Usually it is made of transluscent plastic. Look for leaks or cracks.
The tube is a rubber tube that runs between either the water inlet valve and either the air gap or the inlet spout. Check for leaks.
The water inlet spout - most washers have a plastic spout near the top of the main clothes tub that directs the flow of water into the tub. If the spout cracks or breaks free from it's mounting, it can cause leaks.
These are the things to look for if the washer is only leaking during fill. Hope this helps and best wishes.
Jul 31, 2009 | Frigidaire ATF6000ES Front Load Washer
Dishwasher leaking water from top of washer.
Try this site....have the exact model number ready....it is inside on the drum wall....
http://www.repairclinic.com/GE-Dishwasher-Parts?s=a9b3
Hope this helps....good luck and good day.....thanks for rating me...The Fang.
Mar 13, 2009 | GE Nautilus 24" Built-in Dishwasher
Washer is leaking even when water in waher but washer off
check out you tube search whirpool washer repair, easy to see how to remoe the panel, most likely a bad pump is cause of leak. will be quite evident!! yo can even just tip unit back the underneath is open
Feb 18, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Duet washer leaking
If the leak started occurring after the bellow was replaced, and it's on the left hand side of the door, I suspect the bellow is not seated around the fill tube all the way. I have experienced this problem before. Check the fill tube where it comes in by the door. The rubber should be seated back far enough to allow the tube to fill into the tub without obstruction. It could be that the fill tube is forcing water BEHIND the bellow and leaking into the washer and on to the floor. To answer your question, "YES", replacing the bellow could have caused your leak.
Sep 29, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Water leaking
If it's the hose your talking about, the white tube connected to your tub is called and "air dome" hose. It connects to your pressure switch to shut off your fill valve when selecting load sizes. The hose should connect to a fitting somewhere near the base of the wash tub. If it is leaking, generally mildew inside this tube can cause it slip off it's fitting or lose it's seal. Also the hose can stretch out of shape over time and lose its seal. If you have enough slack in the house, you can pull the hose off the fitting and cut about half an inch off the end, clean the fitting, and reattach. This should reseal it. If the hose itself is leaking, you should replace the entire length of house from the tub to the pressure switch. You can find plastic hose of this type at any hardware store. I hope this helps.
Apr 08, 2007 | GE WJSR2070B Top Load Washer
Whirlpool WTW6400SW Cabrio Washer Logo
43 people viewed this question
Marvin
Marvin
Michael Thomas
Michael Thomas
