Question about Refrigerators
Fix refrigerator when freezer works but refrigerator doesn't
Nothing
Posted by David Coe on
  • callmechaz Jan 28, 2015
    Hi David Coe, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Like, what one is it?
Steve Allison
  • Refrigerators Master
  • 5,569 Answers
In most combination units, the cooling coils are located to favor the freezer and a portion of the cooled air is moved by an internal fan through an adjustable vent into the refrigerator section.
When the compressor is running, look for vents in the rear of the fridge and check to see if there is any air flow noticeable.
If not, there is a good chance that the fan responsible for moving some of the frigid air into the refrigerator side has failed.
Accessing that fan for replacement is highly dependent on the design of the unit.
Get the complete model number of your unit and go to the link below, enter the model number in the search window to see if an illustrated parts breakdown is available.
These are useful in finding if this is a DIY project or not:
Water Filters Lawn Garden Appliance Parts
Posted on Jan 29, 2015
GARF19XXYK00, doesn't cool properly, 36 - 40 deg. F on coldest setting. A & E just replaced the bi-metal , defrost part, thinking the defrost keeps it too warm, but guess what, still the sam
There is a TSB on this (TSB) = Technical Service bulletin. You need a service company to order part number W10599551 and put it on. This will fix the problem.
Feb 01, 2013 | Whirlpool GARF19XXYK 19.0 cu. ft....
Fridge not freezing meats
I was writing a big note here before then hit the wrong button, it was just a bunch of jargon anyway. Yes it is the condenser fan motor causing your problems. Doesn't cool the refrigerant properly than nothing works. I would change the fan before it causes any damage to the compressor.
Sep 04, 2012 | Whirlpool Refrigerators
My refirgerator model number pbf2255hew stop cooling & compressor stop working...tries to come on but won't
Check your fan on the back of refrigerator...Might need replacing..Surly needs cleaning
Dec 08, 2017 | Maytag Refrigerators
My jcd2389des freezer is working fine but the refrigerator isn't cooling properly
Hello Sharleen,
The leading problem when freezer works yet the refrig. section doesn't get cold is going to a problem with a automatic defrost system defect. Do ya see a bunch of frost inside of the freezer on the back wall?? if yes ya do see that frost build up ist defiently not defrosting and this tip i wrote covers what to check when it doesn't defrost http://www1.fixya.com/support/r10097882-wrong_when_freezer_frosted_refrig_warm
GENE
Oct 03, 2011 | Jenn-Air JCD2389G Side by Side...
We inadvertently left the freezer door slightly open the frrezer ran continuusly for twenty four hours. Would this cause the condenser to frreze up and burn out? The frrezer is still cold and we...
leaving your freezer door open does nothing ,but work the freezer harder,,,it wont cause no of the prolems you stated,,it will cause your electric bill to rise ,,your ok...the condenser is part of the seal system and it exspell the heat usally under the fridge...good luck
Sep 03, 2011 | Kenmore Top Freezer Refrigerator
Freezer works/ refridgerator doesn't cool
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 21, 2011 | Refrigerators
Freezer works great but refrigerator. Doesn't get cold its cool but not cold turned thermostat to 33 and ut isn't gettingcold
heatman101
Aug 21, 2011 | Kenmore Side by Side Refrigerator
My Danby refrigerator stopped working after the power went out over the weekend. I have adjusted the temp. dial but nothing appears to make a difference. Is there anything I can do to reset the fridge?
Try to unplug it again let it set 5 min and then plug it back in. If that doesn't do it you may have to replace the compressor relay where the wires hook to the compressor, thats a fairly easy fix on that unit.
May 17, 2011 | Danby DAR483 Compact Refrigerator
Refrigerators Logo
44 people viewed this question
Top Refrigerators Experts
Marvin
Marvin
john h
