Sorry for my bad english. I have a problem with the laptop HP Cq 62 a10sm. When it was cold, he could not start. After overlapping fans, Windows can boot normally. But the problem was getting worse. I pressed the on / off button, and pulled ac cord at the same time. After re-connecting the AC cable, the laptop would be started by itself. After that it impossible turn it off after connecting the AC power cord. Also the screen is completely black. I tried to reset by disconnecting the battery, 60 sec on / off button holding down ... etc. Wireless LED light orange, but there is no indication on the LED caps lock key. is there any solution to this problem? can i flash bios via usb flash drive?
You can generally only flash a bios if you can get the machine to boot up into some operating system. Do you get ANY on-screen logos or messages when you apply power to the laptop? Can you get into the bios when you power up the laptop and press Esc (or F2 depending on your model)? Do you hear any sequence of 'beeps' when you power up the laptop? A series of short/long beeps when powering up indicates some kind of error detected by the Power On Self Test (POST) routine. Do you have the HP recovery CD for your laptop? Have you put it in your CD Rom drive and tried to boot up? Check the manual at HP Support for a hard reset procedure- you could have a bad power button board or other hardware problem-it is not usually a BIOS problem.
First, thank you for your reply. I took apart the laptop so that the speakers are not connected and I can hear the sound. Unfortunately the screen shows no brightness, not text- nothing. I do not hear it spinning hard drive, no lights its LED ... laptop turns on by itself when connected to an AC cable. When inserting the battery, do not starts itself, but when I turn it on the button, it can not be switched off. It's the same when I disconnect the board with on / off button. I do not believe that it is button / board a problem ... I'll check. I will try to measure the elements near the connector battery and ac inputs. Laptop from a friend from work
Exactly what 'sound' are you hearing? Something like fan noise or actual audio? Are there a series of audio tones, short and long, that occur when you try to power up? If so, that is the bios signaling that it has detected a hardware problem. It is also not clear what you mean by the laptop
turning on, when you say the hard drive isn't spinning and no LED's are lit. Are you confusing the charging light (LED) for the battery coming on when connected to AC power with the laptop actually turning on and booting up? The charging light will come on whenever the unit is connected to AC and will not turn off with the on/off button. If all you are seeing is the charging light, and the hard drive isn't spinning, you probably have something wrong with the power wiring or on-board power regulators. Check the service manual link in the original answer.
I will connect the speakers today and see if there is a sound signal
when plug ac cord, leds of charge, wireless orange and LED near to on/off buton lights
i ll chek power regulators today
I checked with a multimeter transistors around the ac power connector. What I see looks okay to me. So, when I connect the connector immediately starts the fan, reduces his speed depending on the heat in the processor. Light: LED ac power, the LED next to the on / off button. when I connect the keyboard lights up the Wireless button. On the screen there is nothing; even lighting, no letters. not flashing LED hard drive. I disconnected the on / off button, and when I connect the AC cable, the laptop starts up again by itself. only it is different with battery. When I connect it, then the laptop will not start by itself, but after pressing the the on / off button. After that, not to be switched off as long as not remove the battery. It seems to me that the motherboard died ...
