Filled dispenser
There are two ways of dealing with this:
1. Leave it alone, checking the rinse aid every month.
2. Find the fault.
The fault is likely with either the level detector, which will probably mean a replacement rinse aid dispenser or with the cabling. Try disconnecting the detector cables and seeing if the light turns off (make sure it's the detector cables, not the doser). If the light turns off, the likelihood is that the detector has failed. If not, then the fault will lie elsewhere, possibly with the logic board.
